Results 1 to 7 of 7
Thread: Possible to run two Intelliflos on a Aqualink?
    Apr 2014
    Georgia
    11
    I have a Aqualink with iaqualink. I recently had issues with a jandy epump prematurely and switched to intelliflo. It was doing so well that I decided to replace my aging booster pump with an intelliflo as well so I could dial in the speed.
    Without making any changes, When both Intelliflos are hooked up they "pair" and run at the same speed. I went into the system setup and changed pump 2 to intelliflo, but I don't think that changes anything unless the system detects it as a separate pump.
    Is it possible to control both pumps independently through the aqualink? If not, would it harm the intelliflo to set it at my preferred speed and have it on a relay through the system?
    Jun 2014
    15,205
    Re: Possible to run two Intelliflos on a Aqualink?
    Hello Robpiat! I see you haven't received a reply yet on your post. I just wanted to let you know we haven't forgotten about you. Server issues have impacted replies a bit. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    Apr 2014
    Georgia
    11
    I'm going to revisit this. I gave up for awhile but trying to figure this out again. Otherwise I am going to remove the vs and put in a single speed pump for the booster. No sense in it rotting outside
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,531
    I did not even know that the Aqualink could control the Intelliflo?? Is this being done over the Serial Cables? If so, when done with the Pentair's EasyTouch, the pump itself has to be set up with a "Pump Address". The default is address 1, but it you have two pumps, then one of them must be set (at the pump) to address 2.
    Apr 2014
    Georgia
    11
    Yeah not sure how to deal with the address issue. Jandy didn't know.
    Basically when two are hooked they both be the same speed
    Jul 2014
    Bedford, TX
    7,531
    Rob,
    I'm still curious.. Are you using the Serial cable for control or some other method?
    Apr 2014
    Georgia
    11
    If I recall correctly it uses two wires vs the typical 4 for Jandy devices
