Thread: New pool fill Ultra 18x42
    Jun 2015
    Rochester/NH
    18
    I've searched & having trouble understanding & finding the info I need. I'm having my pool filled today from a pool water supply house. I've lowered the return on my pool so I can keep the water level around 36" vs the 42". The pool normally holds 6500 gallons but with the lowered level will probably be 500-800 gallons less at least? Do I add liquid bleach today & if so how much. How much stabilizer since I know that is needed as well. My TF-100 is on the way but won't be here in time. I will be running the Intex pump to start & eventually getting a SWG.
    Casey's Avatar
    SW PA
    10,448
    Re: New pool fill Ultra 18x42
    You can use Pool Calculator Instructions to make your calculations.
    Jun 2015
    Rochester/NH
    18
    I figured it at 5700 gallons using the pool calculator but I don't have any test results so I have no idea where to begin. I need to know what to put in it today before I get my test kit & I can't figure that out using the chart? Am I missing something obvious?
    Jun 2012
    MA
    347
    A quart of bleach would be a good start. Then add CYA. If you don't have a test kit add about 20 oz of bleach every day.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,542
    I'm not familiar with a pool water supply house. Does the water come already balanced? If so, then they should be able to tell you what your starting levels for FC and CYA are.
    If it's just tap water, plug zero into Poolmath for those values and start from there.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
