Thread: New Base for Pool - Question About Pavers
    Jul 2012
    San Diego, CA
    96
    We are in the home stretch (YAY!) of pool 2.0 build, but I have a question. Due to gopher issues, we built up a frame for our pool(using treated lumber and lag bots, then reinforced with rebar) and plan to do the following:
    weed cloth
    3" of plate compacted class 2 road base
    foam boards taped together with flashing tape
    Pool
    My question: do I still need to put pavers under the legs if the pool is resting on compacted road base? Is it even pavers that you use for a rectangle pool?
    Taking lots of pictures of the process!
    NEW POOL : 9 x 18, 48" deep - Bestway brand, 1 HP Intex 3200 Pump/Sand Filter Combo, Wanda the Whale, Hayward through wall skimmer (still in box)
    OLD POOL 5,100 Gallons, 9 x 19 used Splash a Round, Intex SWG, 1.5 HP Hayward Power Flow LX pump, Pentair Clean and Clear 150 sq. ft. filter, hard plumbed, Wanda the Whale,
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: New Base for Pool - Question About Pavers
    Yes, it is better to have the legs on pavers that are about 2" thick. Pavers provide a more even surface for the legs to rest on, and will spread out the downward forces on the legs from the weight of the water.
    Love TFP? Become a
    TFP Supporter!
    Jul 2012
    San Diego, CA
    96
    Thank you! Road base to be delivered today!
    Apr 2013
    Argyle, TX
    77
    Sounds like a great base for the pool😃
    Jul 2014
    Oakbank, Canada
    389
    I would still put the pavers.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
