Thread: Lost DE through Multiport Valve
    Oct 2013
    Houston, TX
    31
    I took the filter apart, cleaned the grids and recharged the filter (5 lbs of DE). After about 30 minutes, noticed that the pool level was down. Discovered that the spider gasket on multiport valve was mangled. After changing the spider gasket do I need to replenish all the DE? One away to know for sure is to dismantle the filter. Any other ideas? Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Lost DE through Multiport Valve
    If you don't see any DE in the pool, the internal leak probably was before the filter and you should be okay. If there's DE drifts ion the pool, vacuum them up and backwash and recharge with 80%
