Thread: Old pump on new Pool
    Jun 2015
    Fresno / CA
    3
    Hi,
    i just bought a 15'x48 above the ground pool. Now last year i had a 10'x30 easy pool which broke. I have the old pump left. Its a Flowclear. Very small one, though. My idea was to use it also with the new pool. I want to put it on the side and let it suck out the water from the top and then sprinkle it back in. Now i dunno if this pump can do this? Its not sucking water in. Tried different hoses, but nothing helps. When i look thru one of the holes i see the little propeller spinning?! Anyone tried such a thing and knows how to make it work?
    Thanks
    Apr 2013
    North OKC Area
    300
    Re: Old pump on new Pool
    Your hoses should be going into the side of the pool, not over the top. The pump probably isn't self priming so it will not work over the top rail. An intex 4400 gallon pool uses a 1000 gallon per hour pump so if yours is that size, it is probably sufficient, although if you cannot hook it up and need to buy something, I would get a small sand filter setup.
    Jun 2015
    Fresno / CA
    3
    Quote Originally Posted by DanielP View Post
    Thanks for the answer. I was hoping there is some "Trick" i can pull off to make it work, but i kinda know it will not...
