Results 1 to 14 of 14
Thread: Sealing Travertine coping and pavers
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Since I will be using a SWG system, I plan to seal the Travertine coping and pavers. From what I can find online, Dry-Treat sounds like the best sealer for what I need. Also, when I was looking at the stone place, I ran into another pool owner just getting ready to put in the same coping and pavers as we will be using. He's in the concrete business, and said the only brand he will use for his pool stonework is Dry-Treat. He said they use it to protect all their concrete work, and it is the only brand that won't eventually turn yellow. I know that's not expert research, but it sounds good to me.
    The guy who will install our Travertine pavers said it is not necessary to seal it, but already I've gotten a few small stains on the coping, and we don't even have water in the pool yet! So I want to take the more cautious route and seal it all.
    Because of the current issues with the site, I'm having a huge struggle trying to research the site. So I'm hoping someone will see this thread who has experience and can be able to post.
    What is the best way to apply?
    Is there a better time of day or outdoor temperature to consider when applying?
    How many coats if more than 1?
    What tricks did you learn that worked for you?
    FYI: if you live in the NW Houston/Woodlands area, I found a good price for Dry-Treat 40SK. MCA Systems in Tomball sells it for $198 a gallon. Their number is 281-255-4622.
    Today on Amazon, it's going for $245 a gallon (free shipping) and MasterTile sells it for $238.09 a gallon. Every little bit helps, right?! Thanks for any suggestions and tips you can share! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Mar 2015
    Montgomery Texas
    112
    Re: Sealing Travertine coping and pavers
    Suzy, I'm a HUGE fan of Dupont "Stonetech" look it up. (I have used this for years).. I seal my slate every year from weather and it has a very nice enhancer that really brings out the colors of your stone work. Its a bit pricey but man does it work great!!!
    Apr 2015
    Houston, Texas
    3,217
    Thanks, Paris! I will look into it! Keep us updated on your deck - with pictures! Suzy.
    Jun 2015
    Phoenix, AZ
    216
    Suzy, I am planning on using this - StoneTech Salt Water Resistant Sealer https://www.amazon.com/dp/B008CR12V4..._AzaJvbC811SG4
    It's specifically made for Salt Water pools and can be applied on travertine.
    May 2013
    Long Island NY
    419
    I don't have any 1st hand experience with sealing Travertine but I can tell you what happen to a family member that had some sealed.
    My brother has this tile in his home in Fl. When he hired a professional tile guy to seal it, it wasn't done properly and never curried. Latter on he found out that it most likely didn't cure and dry because of very high humidity. The surface was tacky and never dried. In the end it was stripped and reapplied.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Suz, The more I read about this Dry-treat it is sounding awesome... ( I may have to seal my driveway with it ) I am sure you found this maintenance guide http://www.drytreat.com/assets/pdf/m...ry2015_web.pdf
    it is a no slip surface because you are not using "sealer" that you would need to add non slip material to..
    15 year warranty and no reaplying, sounds great The only thing that sucks is to get the 15 year you have to use an "Accredited Applicator"
    Warranty
    If an area of porous building materials is prepared and sealed by a Dry-Treat Accredited Applicator who holds a current license you will qualify for a written warranty. The warranty is between Dry-Treat and the property owner, and states that if the sealed surface is properly maintained but fails then it will be re-sealed free of charge. The Applicator is able to log in through the Dry-Treat web site and generate and email a warranty that will include important details about the job. A failure is a treated surface that does not repel water and/or stains from a non-acidic non-solvent based liquid when compared to an untreated surface.
    Apr 2015
    Houston, Texas
    3,217
    Quote Originally Posted by samt View Post
    Thanks for the heads up! I'll try to make sure that doesn't happen!!! Although these days in our area, finding a good stretch of dry weather will be the trickiest part. I will definitely do a sample test and make sure it dries without being tacky. Take care. Suz.
    Apr 2015
    Houston, Texas
    3,217
    Cowboy: Somehow I missed that PDF. Thanks so much for sending the link! I read more about dry treat last night - a little more on the science side of it, and it's very convincing.
    I have a call into an accredited installer here in Houston to see what they charge to apply it. I would guess it's more than I want to spend, but you never know!
    Say, why don't you go ahead and use it on your driveway, and let me know what you think?!!! Just kidding! Thanks again for the info. Take care. Suz.
    Jul 2013
    Fletcher, OK
    3,353
    I'll get right on that... ohh wait, I have to start my above ground install saturday, may have to wait.... too funny
    Jul 2014
    New England - MA
    310
    I've been told by many FL travertine installers they use the stonetech salt water resistant sealer.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Jan 2015
    Phoenix, AZ
    638
    we're going in the morning to buy some preserve outdoor penetrating sealer. $80 for 5 gallons. the guy at monterrey tile said the trick is getting penetrating sealer, not topical cuz it peels. we were told to get a solvent sprayer pump and some lambswool to rub it off 20 minutes later. got our pool filled this week and today i scrubbed off most of the grout that was spilled here and there on the pavers, rinsed off the dirt and am trying to leave everyone out of the backyard til monday morning, when i will get up at 5:30am to apply it (he said it doesn't stick when it's too hot!). then we have to wait a minimum of 12 hrs before we can get it wet.
    40' x 12' IG shotcrete (3 1/2' 5, 4'), Hayward variable spd pumpSP3400VSP, Paramount PV3 in-floor, venturi skimmer, 14,400 glns, Hayward Turbo salt cell T Cell-15, UV, Hayward DE filter, model DE4820, 2 Hayward Color Logic 320 LED color lights, Hayward P4 w puck. 2" line to in-floor valve (46'), deck mount canister parascoping fountain, leaf canister, Marbella, pebble. new build 6-24-15
    Feb 2016
    Houston
    323
    I spoke to our PB about using the Dupont stonetch salt water sealer to seal our stone and he said he used it in the past, but didn't like the results and now uses Dry-treat 40SK with great results especially salt water pools. I will need to check to see if they are using an accredited applicator to do it.
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    Apr 2015
    Houston, Texas
    3,217
    Thanks, Firehunter! Your post came in perfect timing. As soon as the bathroom re-modelers finish in a couple of weeks, I'm going to have the deck sealed. I was still wavering between products, but I think your post is a sign of what I should use. I haven't found an accredited applicator that I can afford ($3000 before paying for the materials). So, I think I'm going to hire my son and his 'handy-man' friend to do it. There's lots of help with instructions online. This coming week is supposed to be dry and sunny (and not too hot) around here, but the timing is wrong for the indoor workers. I hope we get a few more nice weeks before the blazing heat sets in.
    Good luck to you and thanks again for posting your info!!
    Take care,
    Suz
    Feb 2016
    Houston
    323
    Glad I could help. I love that it can last 15 years, but the curing time is 3 weeks.
    Wow that is expensive for an accredited applicator. Our PB said he will seal with it for $325 per gallon.
