Thread: Pool Liner Coming Off
    Jun 2015
    Frederick, MD
    13
    Hi all. My pool liner seems to be separating from the wall. So far, about 6" has come off. Is this something that I can fix myself? Is there harm is leaving it as is?
    We are currently debating if we should keep the pool (see other thread I wrote about how the pool was built if you want to read my ranting). So, I'm trying to do a lot of the work myself, if possible, to save money.
    Thanks!
    16x36 IG 22K Vinyl | Pentair Clean and Clear Plus 420 Sq Ft | 1.5 hp Hayward Superpump | Aqua Collection Turbo Cell
    May 2008
    Long Island, NY
    151
    Re: Pool Liner Coming Off
    Is it coming out of the bead? if so, you may be able to get it back in by pouring some boiling water over the spot and get the liner back in the track. The boiling water will make the liner pliable. After you get it back in, I suggests that you install Liner lock. http://www.amazon.com/Beaded-Ground-.../dp/B002ZJ3LD2
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
