Thread: Got a question.
    May 2015
    Jonesboro, AR
    32
    Got a question.
    I got my kit yesterday and was proceeding to do a FC test. Water turned pink then added the agent to make it clear....well, after it turned clear I began to record the number and looked again and it started to turn just a little bit pink tint again. I added a couple more drops and it finally stayed clear. I assume I count the number of drops it takes to keep it clear or is it normal to have a pink tint once it sits for a bit? Thanks
    18x36 Rectangle, 8ft deep end, 26k gallons, vinyl liner, Intellichlor IC40 Chlorinator, 1.5 HP Superflo Pump, Hayward Tigershark QC Robotic Cleaner
    May 2015
    Jonesboro, AR
    32
    Re: Got a question.
    Having trouble getting on the site. Is it down?
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Re: Got a question.
    It is normal for it to turn pink again after it sits. Do the CC test as soon as you finish the FC test. Count the drops until it turns clear and you're done.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
