Thread: Problem with Hayward 1hp pump
    Jun 2015
    Belvidere,nj
    1
    Just replaced my pump with a new pump. Pump starts and circulates for 1/2 hour or so and breaker trips. I've replaced breaker, outlet,SJ cord from pump to outlet. Tightened all connections at breaker panel. Any ideas?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Problem with Hayward 1hp pump
    Motor is probably overheating and shutting down. Could be interference in the wet end or the motor itself. Since it is new, I would just have it replaced under warranty.
    Mark
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Curious if the replacement pump is the same as the old one. Which model?
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
