Thread: Best way to stabilize a wobbly ladder?
    Jun 2015
    Visalia CA
    3
    We just purchased an Intex 18'X48" inflatable ring pool. The A frame ladder it came with is terribly unstable. I am going to order a mat to go inside the pool to protect the liner. What is the best way to keep the ladder from moving?
    First time pool owners. Any advice from your experiences is greatly appreciated.
    Intex 18'X48" above ground, inflatable ring, 5,455 gallons.
    Includes a 1,500-gallon filter pump (Intex Krystal Clear Model 635T), ladder, ground cloth and pool cover.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Re: Best way to stabilize a wobbly ladder?
    I set mine on some paving stones, drilled holes thru the pavers, and anchored the legs to them using zip ties.
    I don't have a picture with the zip ties installed, but this will give you the idea.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2015
    Cumberland, KY
    3
    I don't have the type of pool you have, I have the 22x52 Intex ultra frame but anyways you could try some stakes over the bottom legs of the ladder maybe 2 on each leg in the front would hold it down and make it easier.
    Apr 2010
    Cache , Ok 10 miles west of Lawton, OK
    37
    put stakes in the ground connect ratchet straps to stakes and the top of ladder on both sides and tighten, but not to tight.
    Retired Army and still serving.
    18X54 round above ground pool
    Sand Filter, 1hp pump
    TF 100 Test Kit
    Rover Jr robot cleaner
