Thread: Looking for Answers
    Jun 2015
    Ply
    2
    Looking for Answers
    Please redirect me if this is in the wrong area. I was wondering what I would be better off using for chlorine. I have a NG heater and in ground copper supply/return lines and would like to stretch out their lives for obvious reasons.
    Thanks for your input.
    My pool is a circa 1980 18 x 36 Kidney shaped plaster IG, sand filter, approx. 20,000 gal. w/ in-line gas 125,000 BTU heater.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Looking for Answers
    Welcome to the forum!!
    The type of Chlorine does not matter as far as metallurgy is concerned. Once diluted, and distributed in the water, all forms are all identical. It's the amount you have in proportion to your Cya level that matters most. Also, keeping proper control of pH is even more critical if you are concerned with preserving the Copper piping. If you don't have one, I cannot recommend strongly enough that you get a very good test kit and start using it ASAP.
    Essential Links:
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    For metals, I believe pH is the important factor. A low pH is bad for metal pipes and such. Along with maybe CH because of scaling
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Here's a good argument against acidic trichlor pucks and for getting a test kit and using it often.
    Maintain your chemicals correctly
