Results 1 to 14 of 14
Thread: TV and Music Poolside -- Need help Swamp Rabbit
    Smile TV and Music Poolside -- Need help Swamp Rabbit
    Hello Friends,
    I want to be able to hear my outdoor kitchen tv from the pool, without deafening the people closer to the tv. Im interested some kind of speaker set up, but know nothing about this. I also want to set up some kind of music setup. Im looking for ideas on what I should purchase.
    Thanks.
    Feb 2015
    Austin
    133
    Re: TV and Music Poolside -- Need help Swamp Rabbit
    Quote Originally Posted by Swamp Rabbit View Post
    TTT,
    Im interested in something like this also. Any suggestions? I just want to be able to hear the tv from the pool, without deafening the people closer to the tv. Would like them to still be able to hear it also.
    What is your TV source? Antenna or Cable/Satellite? Do you have a receiver/amp and speakers?
    36 x 16 IG, SWG, FAFCO Solar Heating System, WetEdge Primera Stone Sky Blue Treasure, 8.5' - 3.5' depth, 6' S.R. Smith Flyte-Deck II Dive Stand, Interfab X-Stream slide, 27k gallons, doggy tanning ledge w/ 2 bubblers, 2.75 Hayward Tristar pump, Hayward 425 cart filter, Hayward T-15 Salt Cell, Hayward ColorLogic 4.0 light, Dolphin Z5
    DirecTV box is my source. Dont have a receiver, an amp, or speakers; though Im willing to purchase. Music would be a plus.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Any amp/speaker solution will work, but I would suggest a SONOS CONNECT:AMP. Run audio out from the DirecTV receiver to the AMP and then out to wired/wireless speakers from the SONOS to your pool deck. Volume on the Sonos is independent of the volume indoors.
    With the Sonos App, you can also drive any music you may already own (iTunes) want out to the pool, including many free internet radio sources (Radio Margaritaville, Pandora, Spotify, etc.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    I know this may be a bit confusing because I cut and pasted from a Adobe file. This is the set-up I installed.
    1 C4-SR250RSK-B SR-250 Remote and Recharging Station EA $300.00 $300.00
    C4-HC250-BL-1 HC-250 Controller with MyHome and EA
    Intercom Licenses
    1 $750.00 $750.00
    1 C4-16AMP3-B MULTI CHANNEL AMPLIFIER- V3 EA $2,495.00 $2,495.00
    Customize the audio signal to match the speakers and listening preferences for each individual zone./Control multiple zones
    as a single zone with Control4 Media Scenes
    1 C4-TUN2-E-B Multi-Tuner EA $599.99 $599.99
    1 C4-XMOD XM Module for Multi-Tuner EA $199.00 $199.00
    AWR-650-G 2 WAY ROCK ALL WEATHER SPEAKERS EA
    WOOFER AND TWO TWEETERS
    12 $299.99 $3,599.88
    AW-650-W 6.5" IMG Woofer 1" Titanium Tractix PR
    Horn Loaded Tweeter (white)
    1 $549.99 $549.99
    SB-5510HD-BL 55" Outdoor TV Pro Series 1080p Full EA
    HD, 120 Hz (black)
    1 $5,595.00 $5,595.00
    1 WM46 Sunbrite 46"/55" Articulating Mount EA $465.00 $465.00
    ENS202EXT 2.4GHz Wireless N300 access point EA
    supports 802.11b/g/n devices with
    speeds up to 300 Mbps.
    1 $149.99 $149.99
    WCS10-R-EXT-ZP Wireless Contact Relay (External EA
    Antenna) - Zigbee PRO
    1 $179.99 $179.99
    B-500-EXT-230-RS Single CAT5e/6 HDBaseT Extender EA
    (230 ft.), Bi-directional IR, RS 232, and
    POC
    1 $599.99 $599.99
    B3-AUD-2 BINARY CABLE B3-SERIES ANALOG EA
    AUDIO 2 METER
    3 $9.99 $29.97
    B6-HD-1 High Speed Licensed HDMI Cable with EA
    Ethernet 1 Meter
    3 $25.95 $77.85
    1 GSD-802PS Planet 8 Port Gigabit POE EA $279.99 $279.99
    1 PATCH-CAT6-2FT-BLK Cat 6 2ft Ethernet Patch Cable (Black) EA $4.99 $4.99
    1 SR-WM-10U Strong™ 10U Wall Mount Rack EA $299.95 $299.95
    SR-WM-SWING-10U- EA
    3IN
    StrongT 10U Wall Mount Rack Swing
    Kit
    1 $159.95 $159.95
    EP-400-UPS-8PS-825 Episode 8 Outlet Stand Alone AVR UPS EA
    with RJ45/RJ11 &RG6
    1 $259.99 $259.99
    NST-CAT6-1000-BLU Cables Cat 6 550MHz Unshielded 23/4 EA
    .58mm CMG-Rated Wire - 1000ft Nest
    in Box (Blue)
    500 $0.25 $125.00
    200 CAT6-SH Category 6 Shielded Cable FT $0.50 $100.00
    quote.rpt Printed: 9/2/2013 9:27:07AM Page
    1 $1,499.99 $1,499.99
    1 EA-AMP-SUB-1D-500 Episode Digital Subwoofer Amplifier EA $999.00 $999.00
    SP-164-DB Binary Cable 16 Gauge 4- Conductor FT
    Direct Buriel
    100 $0.50 $50.00
    3.00 INSTALLATION TEAM installation w/ team of techs HR $99.99 $299.97
    Two Technicians
    Item
    Also this sub woofer that gets buried in the ground
    UOM Sell Total
    ES-LS-BSUB-12 Episode® Landscape Series Burial EA
    Subwoofer with 12 in. Woofer (Copper
    Dome | Each)
    This is a Sonos system
    Jun 2015
    Northridge
    8
    uhh... I vote for the Sonos system. Less "B6-HD-1 High Speed Licensed HDMI Cables" you'll have to buy.
    Northridge, CA
    36x18 - 25,000 GAL. IG Plaster
    PAC Fab 36 sq.ft DE filter, Pentair InteliFlo VF variable drive
    Old school Kreepy Krawly, Polaris 360
    Taylor K2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    +1 on sonos.
    We have the playbar and directv in the living room which puts tv sound into the sonos home network/boost and can be rebroadcast on all Sonos speakers in our system inside and out. Or you can play the same music on all speakers or different music on each speaker. All over wifi and controlled from an app on your phone, tab, pad. Pandora, slacker, google play, whatever. It is great!
    Feb 2015
    Austin
    133
    Sonos is nice if you don't mind spending several hundred dollars. You can set up a remote controlled music system for a lot less if you're willing to do a little work.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Quote Originally Posted by tedujam View Post
    The eternal equation: initial cost vs. opportunity cost.
    Not to be too presumptuous, but... if you have to ask what can/could be done, you're probably not the guy that's going to home brew an HDMI -> wireless gateway solution. Get the Sonos, hook it up in 5 min, spend the rest of the weekend enjoying it.
    DFW, TX
    24,509
    Right! Everyone knows how to work a 110v plug and an app on a phone! And it sounds great!
    Feb 2015
    Austin
    133
    Quote Originally Posted by txnole View Post
    eh, not really. I posted in the other outdoor music thread about the basics you need to set a up a cheap wifi controlled music system and the average housewife can throw a system together if she can read instructions.
    Sonos, to me, is like apple. Overpriced and proprietary.
    Back2BasicsMom's Avatar
    Jun 2014
    Central MN
    19
    Or for the budget minded you can pick up a nice sized water resistant, rechargeable, Bluetooth speaker at Aldi and use your portable music device. Works great for our needs!
    18' x 48" Above ground Intex metal frame 6,423 Gal
    Purchased Used (Approximately 3 years old) but new to us.
    110-120 volt Filter Pump with 1,500 gallon (5,678 L) per hour flow rate (Intex)
    Water is from a well
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    +1 for sonos. Expensive but great sound.
    IG 13,000 gal, WetEdge Prism Matrix Indigo Blue, Hayward C4030 cartridge filter, Hayward Ecostar VS main pump, Hayward Tristar VS feature pump, Hayward OmniLogic, Hayward Sense & Dispense (pH only), Stenner 45MPHP22 bleach, Hayward H400FDN Heater, Hayward Color UCL lights, Pentair LED Bubblers. TF-100 XL test kit. Test Results. Build Thread.
    Jul 2015
    Tempe, Az
    123
    Blueooth transmitter and REcIEVER combo. Best buy and amazon have the sony for about $40, then pick up an amplified portable speaker. Well under $100 for the combo. Your tv should have an analog output that will hook directly into the BT transmitter.
    SONOS is excellent, but big $$$ and not exactly portable, so if you have i climate weather your dragging the stuff inside. The portable speakers are really good now, especially in the $60 and up range.
