Results 1 to 9 of 9
Thread: Tan Colored Liner
    Jun 2015
    Sammamish, WA
    5
    Tan Colored Liner
    I saw some old posts on tan liner but many links/photos don't work and hoping to see something more recent to determine if tan may be a good color choice? I am contemplating the tan sierra/gold pebble also seen as stone canyon, but it has a double width border compared to others and not sure if too patchy with blue brick? Will tan keep the water looking blue or aqua, I thought it might look dirty and murky but it sounds like this might not be the case?
    The initial liner in our pool was the color on the right - more light blue, and my husband wanted darker so we did the one in the middle and finally we added the stamped concrete on the left but the pool water in that photo is not clean.
    We had another tree fall in the pool which damaged the liner and coping and now we are changing the white vinyl coping to a similar stamped grey concrete coping. Should we change the color of the skimmer lid and skimmer cover to grey from white to blend better with the concrete or leave white to match stairs? I am not even sure if a grey skimmer lid is available. I have a bunch of stone installed around the front of the house (photo below) and may also add to the back to have a fireplace area, not sure if doing this if the tan sierra/gold pebble liner would also be a good match for it?
    Apr 2010
    Central NJ
    227
    Re: Tan Colored Liner
    I don't know if you saw my posts, but you can see some pics here:
    new pool liner pictures
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Jun 2015
    Sammamish, WA
    5
    that does look pretty nice, but now I have also started to look at grey, Pebbled Paradise, as it may match our grey stamped concrete better. Does anyone have experience with these, ideally would prefer the water to be more aqua.
    joyrox's Avatar
    Mar 2016
    Nashville/TN
    9
    Hi, I'm new to the group! I just bought a home with a steel walk pool and I need to pick out the liner. I want to have a aqua lagoon feel and I've been checking out the tan liners. Do you guys have any more pictures to share? I have a 20 x 40 9ft deep pool with custom stairs! Any help would be greatly appreciated, I just know it's going to be there for a long time and I want the color to be perfect! Thank you!
    joyrox's Avatar
    Mar 2016
    Nashville/TN
    9
    I was thinking of getting the cascade creek liner made by Tara Liners. I have a 20 x 40 old steel wall pool. Any suggestions or Pictures of this liner would be helpful. Thanks!
    Feb 2018
    North Alabama
    12
    I am considering this liner as well. Did you go with it? If so, are you satisfied?
    20,000 gallon L-shaped pool with vinyl liner; Hayward sand filter, Polaris 280; Aquarite SWG; TF-100 test kit
    Jun 2016
    Upstate NY
    71
    That was our second choice, we ended up with gray granite and love our choice, but would of prob been very happy with that as well., take a look at our build...18x40 Igp in over taxes NY..., good luck!
    -18'X40' IGP RECTANGLE WITH 90 DEGREE CORNERS, 8'6" DEEP END WITH 9'X9' HOPPER, SHALLOW IS 18'X11', TRANSITION IS 15'6", 8' CENTER CEMENT STEPS, LINER IS FROM VINYL WORKS "GRAY GRANITE" WITH NO BORDER. HEAT PUMP IS PENTAIR ULTRATEMP 140 (14OK BTU'S), 4 PENTAIR LED LIGHTS, S.R. SMITH TURBO TWISTER SLIDE "GRAY GRANITE", S.R. SMITH 8' TRUE TREAD DIVING BOARD WITH SALT BASE SYSTEM, INTLLICHLOR CHLORINE GENERATOR SYSTEM.
    Jun 2016
    Upstate NY
    71
    We agonized over the decision too and in the end glad we didnít just pick any old thing...
    Aug 2016
    MA
    73
    We got the Garrett Clearwater liner which looks very similar:
    Here's what it looks like with water, although not completely filled yet:
    Pool Build (2017) ~24k Gal IG Vinyl 18x36 Lazy L Pool
    Equipment: Hayward 1.85HP TriStar VS pump, C3030 SwimClear cartridge filter, AquaPlus PL-Plus SWG w/T-CELL-15, ColorLogic LED Light, TF-100 w/Speed Stir, Taylor K-1766
