Thread: Greetings from WV
    Jun 2015
    Wv
    2
    Greetings from WV
    Hello,
    I live in WV and am getting ready to pull the trigger on an in ground pool. Looking at all my options but really focused on a fiberglass type.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Greetings from WV
    Welcome to the forum. You may want to search for the pro's and con's of gunite vs fiberglass vs vinyl before you make a decision.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Hi and welcome to the forum. Like you i was set on a fiberglass pool at the start. One of the most important parts of a fiberglass pool is the install, must be done right or it will crack if not installed level. Plus you will want a good back fill and that's not sand. So your installer/Pool Builder is the big choice you will make. You may only have a few to chose from. Next make sure the pool has a good gel coat. A good gel coat will not crack or fade in five years. On the plus side is that fiberglass pools can install quicker, algae has a harder time sticking to it and they say you can use less chemicals in a fiberglass pool. On the down side is you have fewer shapes to pick from(there are many popular shapes) the gel coat will eventually give out(12, 15 or more years for a good one and not 5 to 7 years as some cheap ones do) not as easy to add a spa or waterfall to a fiberglass pool. Hope this helps.
    By the way, the reason i didn't go with a fiberglass pool is the only fiberglass PB in my area that i would have trusted never returned my 3 phone calls nor my two internet request.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Jun 2014
    15,189
    Hello and welcome to TFP. I'm a FB owner and absolutely love my pool. If you have any specific questions about the selection process, installation, or care/maintenance of a FB pool, feel free to message me and I'll be glad to expand. You can see pics of my pool (before, during install and after) below at the "My pool" link below. Welcome and have a great day.
    Casey's Avatar
    SW PA
    10,450
    Welcome to TFP neighbor!
