Results 1 to 8 of 8
Thread: Cloudy water after party with 18 kids
    May 2015
    Brooklyn NY
    46
    Hello. I should of asked this group before the party but I forgot and now probably paying for it. As of this morning my FC was at 8.5 and PH was a nice 7.6 with crystal clear water. My daughter had a graduation party with 18, 10-11 year olds swimming for about 4 hours straight. I told everyone a basic rule of No Peeing in the pool but I bet that went to deaf ears. After the party my water is pretty cloudy. Looks clean but cloudy. I put my swg on 100% output to try to kill whatever bad stuff is in the water. I havnt tested the water yet but is there any suggestions to get my water crystal clear again?
    I have what could be another issue. I set my swg to super chlorinate but the super chlorinate light wouldn't turn on. I tried a few times of turning on and off but still no go. So I set it to auto and turned dial to 100%. Is setting to 100% same as superchlorinate? I will have teh pump running non stop until pool is clear again. Thank you for the responses.
    Salt Water 8000 AGP 12' X 18' X 54" - Hayward S166T 16" Sand Filter w/ 1.5HP Power-Flo Pump - Hayward Aqua Trol RJ Salt Generator System
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cloudy water after party with 18 kids
    Need to know your CYA level.
    I would bring the pool to shock level for your CYA using bleach and then perform an OCLT.
    # Sent from mobile device. Beware of brevity and spelling errors!
    Isolated Spa - 345 Gallons
    Jul 2014
    Peoria, IL
    389
    Had a similar situation. Had a pool party over the weekend with 10-12 adults and kids. I never take my swg off of 80%, the setting that works for "normal" use. And I never ever use the super chlorinate setting as I do not want to shorten my cell life any more than I need to. I simply keep liquid chlorine on hand for just such situations. I know the purists on here will yell at me and tell me to use my Taylor kit to get the dosage exactly right but I blindly dump in about a half gallon and it keeps me good to go until the next weekend when I test the chemicals again.
    Where is your FC reading now? It is probably just sunblock and your normal production of FC got used up trying to eat the contaminants and sunblock.
    As to your super chlorinate not working I am of no help. Try to unplug the unit and reset it??
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    May 2015
    Brooklyn NY
    46
    I just did a water test. My FC is 6.5, PH is 7.6-7.7 and CC is 0. CYA is around 50. Currently the swg is at 100% output. Since my FC is at 6.5 should i lower the swg % output? Thank you
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    it will be fine, it just takes a couple days to clear up in my experience so far. have had a couple LARGE parties with massive amounts of kids and its always cloudy after. i pre chlorinate up to 8 and ended up with 1 the next morning the last time - added a jug of chlorine bleach, filtered for a day, and the next day it was clear again. sounds like you have enough chlorine, it just needs to time for the chlorine to chew up the sweat and sunscreen (and maybe pee) and for the filter to...filter. just my opinion from what i've witnessed. the only question i have is why you are running your SWG so high when you already have enough chlorine? if you want more just dump in a jug.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    I add bleach to get FC to 10-12 before the party and test and back to 10-12 after the party and test again 2-3 hours later and back to 10-12 one more time. This usually gets it clear for the party the next day.
    May 2015
    Brooklyn NY
    46
    I resolved my super chlorinate light not turning on. Turns out you have to have the swg and pump running first in auto mode with a % set and then flip switch to super chlorinate. I had it running overnight and came out this morning to a clearer pool. But my filter pressure shot up to around 19 and it looks like cloudy water is coming out of my return. I didnt have time to work on it before work so I left it on and plan to backwash when I get home tonight to drop the pressure back to its normal 15psi. Im also going to pick up a gallon or two of bleach. If my FC is below 10, should i just spill a bottle in the pool just to raise the FC to help clear the water?
    DFW, TX
    24,483
    Yep, I add bleach fairly often to help the SWG as needed rather than tweaking times and percentages. It's easier and faster.
