Thread: Another question about metal stains
    May 2009
    Trenton NJ
    497
    Some may know I been battling stains. Do u think it would be wise to bypass my heat pump since we don't use it much anyway. My thoughts are the metals/ copper can be introduced to the water by way of the piping.
    I have city water so I'm not sure how much if any are in the water supply.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Another question about metal stains
    There won't be enough Copper in the City water to cause staining. If you keep good pool Chemistry, there should be no issue with Copper introduction from your HP.
    Essential Links:
    Jun 2014
    15,093
    Welcome back ethany! Yes, there have been some cases of copper being introduced into pool water from the heater. Typically it was because they were noted as being either older, rusty, deteriorated, or were somehow poorly maintained. If the system has been maintained in good quality condition that shouldn't be a factor. During your battles with stains, have you actually had the water tested for metals? I don't recall if you did. If not, that's one of the very few tests we do recommend having performed at the pool store (for metals), then we can advise more from there. But just go there to hear the metals results. When they start talking about anything else, just smile and leave.
    May 2009
    Trenton NJ
    497
    May 2009
    Trenton NJ
    497
    Had my iron n copper tested at pool store. Came up zero for both. Makes no sense how a AA treatment removed stains, they come back yet no metals in the water. Explain that......
