Thread: Aquabot Turbo T - need troubleshooting help
    s9601694's Avatar
    Oct 2013
    Conroe, TX
    90
    I picked up an Aquabot Turbo T from craigslist today. The seller said that it worked fine until the fuse on the power supply started to blow. He gave it to me for $100. I figured that to be a pretty good deal!
    So this is the situation:
    - power supply works and turns on. I can start a program and it'll does fine
    - the fuse blows ONLY when the cable is plugged into the power supply AND a program is running. I.e. when power is being sent to the robot.
    Any ideas? Bad cable? Bad power supply?
    Thanks!
    See my POOL!
    Free form pool, 128 ft perimeter, max length 42ft, max width 38.5 ft, depth 3.5 - 8ft, Chilean Beach Gold Pearl Matrix, 13 ton moss rock waterfall, tanning ledge with 3 gushers, PV3 i, LED underwater lights, automatic water leveling system, 1424 sqft deck.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Aquabot Turbo T - need troubleshooting help
    Boy I don't know, but that cleaner looks like he's ready to retire. Looks like it's been a good one for you.
    Essential Links:
