Thread: Jacuzzi Filter Questions
    Jun 2015
    St. Louis/MO
    1
    I recently moved into a home with a nice 22,000 gal pool with a Jacuzzi sand filter.
    Question 1 - Where is the model number located on the sand filter? I have looked everywhere but many of the tags are worn or have fallen off.
    Question 2 - What is the inspection plug used for? If my sand is low, can I add sand through the inspection plug instead of taking off the top unit?
    Thanks in advance for any help provided.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Jacuzzi Filter Questions
    Welcome to TFP!
    I'm sorry I can't help, but I wanted to say hi, and welcome to the forum. Hopefully a bump will get you some answers. If your Sand filter is like most, sand will be added from the top only.
    Essential Links:
