Thread: Glad to be on the forum- Great support here.
    Jun 2015
    California
    9
    Greetings y'all. We installed our SWG, 30K gallon plaster pool last August. This is our first pool and we have been doing lots of research on how to maintain it. TFP.com has been an excellent resource so far. I really have found the calculator to be so useful helps make the needed chemistry changes easy. Thank you. I am going to add Borax to my pool, but am a little anxious. Currently, however, I am working on lowering my TA from 110 to 80. The explanations on the forum have been helpful in doing this. Looking forward to learning more about the pool care as I go through the forums.
    30000 gallon in-ground rectangular, 38Ft by 16Ft, Plaster, 4Ft to 8 1/2Ft deep, SWG, Jandy Nature2, Pentair IntelliFlo Vari. Speed with remote, Installed 8/2014.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Glad to be on the forum- Great support here.
    Hi Sparty!
    Welcome to TFP!
    Divin Dave,
    Jun 2015
    California
    9
    Hi,
    I notice your auto-fill is disabled. Please tell me my you did this. I need to adjust ours so the level is lower. Do you know what direction to turn the lever to lower the level? How much should I turn it? The water level is currently at about 4/5 to the top of the intact and close to the top of our tile. Thanks for your help.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
