Results 1 to 10 of 10
Thread: What is the ultimate filter?
    Feb 2012
    Maryland
    400
    Serious question, if money was no object, what filter would you suggest I use for an 18x36 IG Vinyl?
    Just curious what the best of the best is.
    Best meaning
    1. Works great.
    2. Not overly complicated maintenance.
    Of course money being no object is not quite true, but let me dream
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    38,299
    Re: What is the ultimate filter?
    All filter types have pluses and minuses. Comes down to personal preference. There is an article in Pool School comparing filter types.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Oversizing a filter is recommended. A larger filter wil not only perform better but will need cleaning much less often. As far as the choice of type of filter, just do a bit of research. Do you want the easiest to maintain or the one that filters the finest?
    chiefwej
    38,299
    Feb 2012
    Maryland
    400
    I would actually prefer a filter that filters the finest. I enjoy working on and around the pool, so maintenance is not a real issue but I am obesessed with clear water.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Quote Originally Posted by ssgumby View Post
    Generally that means you would be looking for a DE filter.
    My Hayward 6020, installed in 2004, does a great job on my 20k gal vinyl lined pool.
    And as was mentioned, oversized is the way to go!
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    30,421
    Attachment 38774 Size matters
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    In that case, right here: it will filter out everything and return essentially distilled water to your pool
    A DE filter is much more practical, though.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    DE will give you the finest filtration, fairly low hassle. Sand won't filter as fine, but is easiest to maintain and use. Adding DE to a sand filter after each backwash can also help it filter finer particles. Cartridge filters catch particles nearly as small as a DE filter and are a bit of a hassle to clean filters, which must be replaced periodically depending on how well you maintain your pool. Since you're going to be closing your pool for the winter, sand and DE filters make it easier. See a better summary here: Pool School - Pool Filter Comparison
    Isolated Spa - 345 Gallons
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If you want very fine filtration and are willing to do maintenance to get it, I would recommend an oversized DE filter and use cellulose filter media in place of DE.
    chiefwej
