Thread: How often to replace test kit
    May 2014
    Midland, MI
    100
    Last year, I bought the TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD, and I still have items left over. I am wondering if this is something that should be replaced each year or if the testing liquids would still be okay to use this summer as well.
    AGP
    16' x 32' x 54" Chesapeake
    Hayward S230T 23" Sand Filter System 1.5-HP 2-Speed Matrix Pump
    Raypak 206,000 btu ng Heater
    Mar 2011
    Grand Rapids, Michigan
    279
    Re: How often to replace test kit
    I replace mine every 2 years. Others go longer I believe. I just feel more comfortable with 2 year plan.
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    30,414
    From a Taylor standpoint, your reagents are all expired. That said, if you have had them stored inside, you are probably good for another season (but there's always that lingering doubt)
    Mar 2007
    San Rafael, CA USA
    12,082
    See this post for my suggestions by reagent. Basically, the organic dyes are most sensitive and the Taylor recommendation for annual replacement is conservative. If you keep them in a cool place indoors away from sunlight, then they should generally last 2 years but I wouldn't push it beyond that. The acids and bases last essentially forever and I believe the CYA reagent is quite stable as well though I probably wouldn't go more than 3 years on that just to be safe.
