Thread: Installing new whisperflow 2.5 hp
    Jun 2015
    Austin, Texas
    15
    Replaced a whiperflow 2.5 hp sf 1.05 with new 2.5hp uprated. Does this matter? Second had to use a lot of teflon on pump suction side almost 20 wraps sealed well and couldn't get pressure side to seal without a little leek. Tried 20 wraps but didn't want to go anymore in fear of cracking any kind of sealant better than teflon tape or tips would be appreciated. The male pipes are the grey ones for high heat and have had trouble in the past with these.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Installing new whisperflow 2.5 hp
    I don't think they make a WF 2.5 HP with a 2 SF. Or did you mean 1.2 SF?
    A full rated and up rated pump with the same label HP are different in "power". What is the application? Too large for just pool. Do you have a spa too?
    Mark
    Jun 2015
    Austin, Texas
    15
    No spa its just a pool with the in floor cleaning system. The pump is uprated.
    Jan 2012
    340
    20 wraps of tape seems a little excessive. I typically use 3-4 wraps and a bit of pipe dope.
    See link below for hi-temp union that I try to use so there are no issues. You can tighten fitting without cutting pipe.
    Hi-Temp CPVC Union 2 in.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
