Thread: Replacing an Intex pool liner with an overlapping liner
    Jun 2015
    Coloma, Michigan
    1
    I have an 18' x 52" Intex Ultra Metal framed pool that needs the liner replaced. When I stored it a couple of years ago, the mice got into it. I tried to get a replacement from Intex, but they no longer carry that liner as a replacement. I had some pretty big holes and decided that I would try and repair them, which would be cheaper than replacing (at that time) a year old pool. I have been researching and still am not able to find a replacement cover for that exact pool. Needless to say, I will need to replace it this year, but probably with an overlapping cover. I have read where people use tarp grabbers to attach the liner, but not sure how that works. Can someone give me some pictures, so that I know how it works and what it would look like? What size liner is recommended to use for the replacement liner? Thanks. Dstreet.
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Re: Replacing an Intex pool liner with an overlapping liner
    HERE is a thread on it with good info.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
