So, I have a filter with the "fingers", not the grids. Before starting to set up my pool last week, I did a full cleaning of the filter, soaking the fingers, cleaning out the whole filter mechanism, etc. Added new DE, good to go. My pool was very dirty, so we had a lot of algae to clean up doing a SLAM. Had to bump the filter extremely often the first couple days of the SLAM. Seems to be okay today with bumping less. However, with the amount of nastiness we had to clean, i thought it would be a good idea to do the "cleaning" option on the side of the pump, rather than just bumping. So here's where I have questions:
I am a total noob at this, pool came with the house. So, the instructions say to start out like you're bumping, but do it 8 times. Then open the release valve on top, and then the drain on bottom and let the filter drain, right? So I did that and it looked to me as if DE itself started pouring out of this drain. I kinda freaked out because that didn't seem right to me and plugged the drain back up again before losing my DE, and ran here to the message boards! Was I doing something wrong? Or does that sound right? If it's right, it made a pretty nice mess!
