Thread: Bad check valve
    crusemm's Avatar
    Sep 2011
    North Texas
    31
    Bad check valve
    I have a 2" Ortega check valve who's disk has failed for the second time in a year. I would like to replace it with a new valve, but due to the limited room, not sure that I can. The pipes and valves are all right next to each other tucked in behind the heater. I am looking for options for replacement or repair. The check valve feeds my spa which is above the level of the pool. So every night when the pump kicks off, the sp drains back to the pool. Pictures are attached.
    21,000 gal In Ground Plaster pool; Nautilus FNS 60 DE filter; WhisperFlo WFE-6 pump; Polaris booster pump and pool cleaner;Rainbow Lifegard HiFlow Chlorine Feeder (not in use); Purex Triton pool light;Hatteras spa light; Intermatic model PF122T Freeze Sentry pump controller; Sta-Rite U-3 Skimmer.
    22,553
    Re: Bad check valve
    Those Jandy valves are designed to be piped on the outside or the inside of the cuff, so I'd cut that coupling off right at the end of the cuff and insert pipe into the cuff and cut the pipe coming out of the floor right at the coupling if there's enough room to glue on a new one or elbow and plumb a loop to put a new check valve in.
    Re: Bad check valve
    DISCLAIMER: I'm NOT experienced in repairs at all... but I have had my spa drain into the pool several times myself. It did this again yesterday. Turn off the pump. Look in the back of the Jandy valve, there is a metal switch that can flip up or down. Try putting it in the opposite direction. If it's up, put it down... if it's down put it up. Turn on the pump and see if that helps. It would be sweet if that fixed the problem!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    crusemm's Avatar
    Sep 2011
    North Texas
    31
    Re: Bad check valve
    No metal switch on the Jandy valve. Bama, so your saying to cut out the Ortega valve right on the line where it says patent. And then right below on the flex pvc. I've never worked with the flex pic, is it just like regular pvc?
    Re: Bad check valve
    Sorry crusmm - mine are automated (with a mind of their own.) Good luck!
    Helen
    22,553
    Re: Bad check valve
    Quote Originally Posted by crusemm View Post
    Yes, right near the line that says patent. and I was actually thinking of cutting the coupling that's near the floor off if there's enough room to glue a sleeve onto the pipe that would be left. However, if there's not enough left you can cut the flex off and fittings glue to it just like regular piping.
