Thread: Greetings From Colorado
    jimbowrench's Avatar
    Jun 2015
    Littleton, CO
    13
    I just discovered this forum over the weekend. Not sure where I have been, must have been under a rock.
    Lots of great information here. Some of it confirming what I already know, but most of it gives me new ideas.
    Really interested in adding borate to my salt water pool, in fact I am currently working to lower my TA.
    Most of the time I really don't have any major issues, but with a very wet spring had some algae problems.
    Thanks to all for the useful information so far.
    Cheers,
    Jim
    San Juan Atlantic Deep Inground Fiberglass, 11,300 G; Pentair Clean & Clear Plus 400; Mastertemp HD 250K BTU NG; Intelliflo VST Pump; Intellichlor IC 40 SWG; The Pool Cleaner
    San Juan Royale Fiberglass, Spa 700 G; Pentair Clean & Clear Plus 150; Mastertemp HD 250K BTU NG; Whisperflo 2 HP/2-Speed Pump; Intellichlor IC 15 SWG
    Intellitouch Controls
    38,524
    Re: Greetings From Colorado
    Welcome to TFP!!!
    Algae is ALWAYS a chemistry problem. Meaning the FC dropped too low for the CYA level. See the FC/CYA Chart.
    Rain does not cause algae. But if you get algae, then you need to follow the ShockLevelAndMAINTAIN Process to eradicate it. And to to that you need to have one of the Recommended Test Kits.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by jimbowrench View Post
    Welcome to TFP!!
    Well, give us some numbers... We like numbers almost as much as we like pictures.
    What I quoted is what concerns me. You should not have issues with algae in a properly balanced SWG pool because of rain.
    Support the site
    Jun 2015
    Littleton, CO
    13
    Quote Originally Posted by tim5055 View Post
    Welcome to TFP!!
    Yes It was chemistry leading to the algae. CYA had fallen over the winter, and I didn't have the reagent to test. My Bad!
    Shock, Algaecide, and correcting the CYA solved the issue.
    Numbers today:
    FC: 3
    CC: 0
    PH: 7.6
    TA: 120
    CH: 250
    CYA: 30
    Salt: 3,300
    From what I have been reading, I need to lower my TA to 70, and bring my CYA up to 70. This is a bit contrary to what I have been told.
    I also used pool anti-freeze for the first time this past winter. Could this have left me susceptible to algae?
    Jim
    38,524
    There is no need to really worry about the TA. But, yes you want to get the CYA up to about 70ppm to aide the SWG.
    Algaecide is a band-aid/insurance to try to prevent algae, not get rid of it. And if you maintain the correct FC levels, there is no need to ever add it.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    We had record-setting rainfall in May...over 16"... which is just over half our average annual rainfall. And yet, not a speck of algae. Maintaining proper FC levels is the key.
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
