Results 1 to 7 of 7
Thread: High TA and Low pH. How to fix?
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Friends AGP, vinyl liner, 12K gallon
    CYA = 50
    FC = 5
    CC = 0
    CH = 300
    Ph = 7.2
    TA = 120
    No way to aerate that I can see. Your basic one wall return and one skimmer. How would someone reduce that TA down to 80 without dropping the pH even lower? is 120 bad for an AGP?
    28K gallon, raised beam, plaster/ceramic color quartz with attached spa. TF-100 test kit
    Hayward 1.5HP super pump, DE4800 DE filter, Hayward inline chlorinator w/3" tabs (off)
    Pool: 2 floor drains, 2 skimmers, 3 floor returns, 2 wall returns, 3.5' deep > 8' deep
    Spa: 2 floor drains, 4 jet returns
    38,547
    Re: High TA and Low pH. How to fix?
    There is no real reason to worry about TA. Just keep the pH in the 7s and the TA should balance itself out.
    Some people make PVC fountains to spray the return water into the air to aerate to raise the pH. If there was a desire to do so.
    No reason to worry about the higher TA unless you are bored and looking for something to do.
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    No, not bored,...got plenty of stuff to do. Just trying to help her get everything balanced and squared away. I will let her know to just leave it be and continue her weekly testing. She borrowed my TF-100 kit for a while for pool opening/start-up. Liked it so much she bought her own, with speed stir also.
    Jim
    Mar 2007
    San Rafael, CA USA
    12,082
    Is she using Trichlor? Usually you don't get a low pH with a higher TA unless some acidic chemical is being added such as Trichlor or non-chlorine shock (MPS) or even Dichlor. The TA usually drops over time, but someone may be adding baking soda to keep it up.
    Maybe she doesn't have much aeration or had a pool cover on the pool which prevented outgassing.
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    She did put on a solar cover the other day, would that have done it?
    As far as the Trichlor or Dichlor, I will ask her if she has added any shock to it. I told her to use 8.25% bleach as her choice of chlorine for maintenance and shock if needed.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes a pool cover could lock in the pH in spite of the higher TA so perhaps that was it and the pH might have been low from some product she used.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    The simplest way to get a lot of aeration is to throw some kids in the pool with some paddleboards.
