Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: Algae Dead But Not Yet Clear
    Jun 2015
    KY
    21
    Hi. I've just purchased a Taylor K-2006 that should be here in a week. In the mean time, I still only have my basic OTO test kit.
    The pool was green and chlorine levels were almost 0. I've added a total of 17 lbs of cal-hypo in the past week. Last night seemed to push the levels enough to kill the algae because the green is gone today. The pool still isn't clear but there is nothing floating.
    I'm wondering what I should/can do now while I wait on the K-2006. I would hate to let it get out of control again. I don't have reliable readings on anything right now besides that my OTO kit says PH is between 7.2 - 7.8 and the chlorine is off the charts. I can say that I added CYA about a month ago based on pool store recommendations, so CYA should be some > 0.
    I appreciate any advice.
    18,000 Gal - Vinyl IG - Hayward Sand Filter - 20 year old pool
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Algae Dead But Not Yet Clear
    Welcome to TFP!!
    First, please stop using CalHypo until you get your test kit and find out where your CH level is. If my math is right 17 pounds should have raised your CH a little over 50ppm.
    Just because you see nothing floating and it's not "green" doesn't necessarily mean all the algae is dead.
    I would say add one 121oz bottle of 8.25% bleach each day until the K-2006 arrives as a holding pattern. Keep the filter running and backwash when you get a 25% rise in pressure.
    Brush the pool each day. can you see the bottom to see if there are any leaves/junk that need to be removed?
    Support the site
    Jun 2015
    KY
    21
    Thanks. I won't add anymore CalHypo. I can't see the bottom now, but I have laboriously raked the pool for close to 2 months to keep debris out. There was a little today. I can't say for sure that it is all out though. I'll add bleach each day. Did you really mean 121oz of bleach or is that a typo for 12oz?
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by mikemod View Post
    No typo, 121oz is the standard bottle of 8.25% bleach. That will only raise your FC by 4.5 each addition.
    Support the site
    Jun 2015
    KY
    21
    Ok thanks for the clarification. I've never used bleach in fear that it would fade the liner. I've since read that this isn't true as long as its added properly.
    May 2015
    River Falls, WI
    124
    Welcome!
    I would suggest start using PoolMath: http://www.troublefreepool.com/calc.html and get familiar with it until your kit comes.
    How much CYA did you add a month ago? If you can estimate the quantity added you can use the above link to figure out where your cya level is approximately. Then use that cya figure and plug it into poolmath and start setting your FC targets based on your best guess. Here's the chart to know where to set your FC based on your CYA: Pool School - Chlorine / CYA Chart
    You could easily and safely be pouring 1 jug of 8.25% in per day maybe even two without a sweat.
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Jun 2015
    KY
    21
    Thank you! Based on the amount added when CYA was 0(from PS analysis), and estimating the refill I've done, I would say its around 50. I added 15lbs of CYA which would have brought it to 100. Why would they tell me to do that? Isn't target CYA around 30? With those estimates, my target FC is 6 and my shock FC is 20. Though, I'm not sure at this point I can even test FC.
    May 2014
    Franklin, NC
    9,184
    Depending on how much sun the pool gets every day you may want anywhere form 30 to 60. Out west, like AZ it may even go higher. Remember, the guy behind the counter at the pool store may have been mowing lawns or flipping burgers last week. There is little training other than sales. What they generally learn is on the job. Did he sell you the CYA?
    Support the site
    Jun 2015
    KY
    21
    The pool gets tons of direct sun every day so that may be something I need to factor in. The pool store is a family owned store ran by a couple with no employees. I've dealt with them for a few years now and generally trusted them until this summer when their sales tactics seemed to become much more aggressive. I would almost guarantee that they've attended some new sales training in the off season this year. Basically, I came in with some green water that tested a CYA of 0. They had CYA in stock, but I needed more, and it would be "a better deal" if I waited until the next day until the bigger supply came in. They've used that a few times now. I sent my girlfriend to the store to pick up 5 bags of CalHypo($20) and she came home with 24($100.) All the while, following their instructions, my pool hasn't been clear once this year. Anyways, I'm done complaining about it. Everyone here knows about pool stores and I should've paid heed years ago. I understand the SLAM process, which is basically what I've always done, just blindly, without accurate numbers to work with. So now I'll wait for my new kit. I'm pretty sure I'm on the right track right now thanks to everything I've read here.
    May 2014
    Franklin, NC
    9,184
    Do they have any other lines of business?? Lawn furniture, BBQ, Big Green Egg??
    The pool business was a difficult one even in good times. Now with the internet the business model is changing and many stores are not dealing with the change well.
    They have many things working against them-
    *Generally people with pools need to have expendable income in today's economy many who did, don't
    *It a seasonal business - Their audience only cares about pool stuff half the year
    *Many of the products they carry are now available on line
    *There is a more informed consumer, sites like TFP are showing customers a different way.
    You may be at the higher end of CYA once the pool is clear and you can get a real handle on your chlorine consumption.
    Support the site
    Inflatableman1's Avatar
    Jun 2015
    Playa Coronado/Panama
    62
    I had to use the google machine on "the big green egg". Never heard of the thing....
    Ryan
    41' x 16' x 5' IG, 25 000 gallon, cement, tile w/epoxy grout. Overflow/negative edge style. Pentair 4048 DE, Hayward 2 hp Single Speed, Pentair 320 Auto Chlorinator, 1.5 hp Blower f/Jacuzzi, TF-100, city/well (in pool) water option. Located in Panama.
    Jun 2015
    KY
    21
    I've received my k-2006 today and have some results:
    CYA - 75ppm
    FC - 2ppm
    CC - 1.8ppm
    PH - 7.2ppm
    TA - 100ppm
    Water is not green but murky right now. My question is, should I just start the SLAM process now, or should try to bring the CYA level down some?
    Thanks!
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Drain some, but get the slam going asap. I like my cya between 50 and 70.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    jwhop3's Avatar
    Jun 2014
    Rocky Mount/Virginia
    78
    I quit going to pool stores for chemicals when (A.) they would test my water with a test strip then tell me I had to buy their chemicals to get the test results, and (B.) when I found this site. Wal-Mart, Krogers and Lowes gets all my pool money now.
    Quote Originally Posted by tim5055 View Post
    Jun 2015
    KY
    21
    I drained some off today. Not the 20%ish to lower cya to 50, but quite a bit. Refilled. Then I added 6 bottles of 121oz of * 8.25% bleach. I think I was supposed to add this a little at a time, but I test FC today and is was 0 after being 2 yesterday. We had a lot of rain last night. Is it normal to lose 2ppm that fast?
    Is it ok that I added that much bleach at one time in order to start the SLAM? I calculated that 6 bottles would bring FC up to 27 which is should be shock level right now. I plan to retest everything in the morning. I should have a better picture by then.
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    How is the SLAM going?
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Aug 2013
    Arab, Alabama
    422
    Yes, you can lose 2 ppm that fast. Algae consumes FC rapidly! What is your current CYA after the drain and refill? The FC you need for the SLAM changes with the CYA. If your CYA is 70 then putting 6 bottles in all at once is fine. You should be testing FC more than once a day. Remember that you must maintain a FC of 27. If it drops below 27 add bleach to keep it at 27. At first I tested 4 to 6 time a day during a recent SLAM.
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    May 2014
    Franklin, NC
    9,184
    With 50 CYA the shock level you need to get to and hold is 20ppm.
    Have you started?
    Support the site
    Jun 2015
    KY
    21
    Quote Originally Posted by wjaneala View Post
    No great so far. We've been getting a lot of rain so after the first 6 bottles of bleach I stopped. But, my FC is still up so I have a good base to re-start from.
    My CYA is 65 after the partial drain. So I'm gonna keep slamming and keep the FC level up. My numbers today were:
    CYA - 65
    FC - 8ppm
    CC - 1
    pH - 7.2
    I just need to maintain the shock level long enough to pass all the tests. Is there anything I should be doing differently? I have a lot of CalHypo. Could I be using this instead of bleach, or will it raise my CYA?
  20. Back To Top    #20
    May 2014
    Franklin, NC
    9,184
    CalHypo raises CH, not CYA but is not as fast to react as liquid products. With CYA 65 you are looking at a 28ppm shock level.
    Bring it up to shock and test and readjust back to shock as often as you can, but not more often than once each hour.
    You should brush the pool once a day
    Support the site
