Results 1 to 18 of 18
Thread: OMG!!! Aren't there "pool boys" that do this anymore???
    Jun 2015
    Southwest, Oklahoma
    8
    I have a 20' round vinyl above ground pool that I bought late last summer. I skimmed your forums and bought the test kit you recommended and made it through the end of summer finding out that I'm a water baby. I love, love, love swimming and I didn't even know it till then. I kept the pool pretty good over the winter but it was frozen a lot so could not do much. Spring at last! Then rains, flooding, more rains for the last 2 months here. Didn't do anything but add some Chlorine bleach a couple of times. Now rains have stopped at last and heat is setting in and I'm ready to swim but I have a slightly green mess. It received a lot of rain water and besides the green there are water bugs. I originally filled the pool from our water well which is extremely high calcium but managed it last year with muriatic acid, bleach and regular testing and sweeping sediment on the bottom. I got the test kit out today and started testing, beginning with calcium and it said 720 PPM. (if I did it right. Still trying to figure some of this out) and 0 Free Chlorine so I thought I'd stop right there, before I do anything else and see what to do before I do something to make it more difficult. I tried to buy water to fill the pool but it seems to be unavailable in my area (I'm rural) so filling from my water well is the only option. We do not have a softener. Am I a hopeless case? Should I drain and start over? Or will you have me happily splashing around soon??? I have read some other posts but didn't find any with water as hard as ours.
    Dry docked and land locked
    in SWOK
    SWOK, 20' above ground, round vinyl pool, approx. 8k gallons.
    Jan 2014
    Buckeye AZ
    807
    Re: OMG!!! Aren't there "pool boys" that do this anymore???
    Why are you concerned about the calcium hardness level if you have a vinyl pool? Do a SLAM to kill the green stuff and then maintain your pH and FC levels. 750 isn't even all that high.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    30,403
    Welcome to the forum.
    CH up fairly high like that can be an issue so they must be managed. You also report a CH of 720 which is not a valid number. double check your math and report back
    That said, I doubt you are in any particular trouble but you have to give us some numbers to work with.
    pH -
    FC -
    CC -
    TA -
    CH -
    CYA -
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Three things about the CH level.
    One: that test requires a lot of swirling. Three times more than you imagine, at least. My CH level went down 200 just by testing with a speedstir. So it's probably not as high as you fear.
    Two: you can do the test with 10 ml of water and each drop counts as 25. At your levels, it doesn't really matter if you measure 710, 720, or 725.
    Three: high CH can cause scaling in a vinyl pool. Low CH is no problem, but high CH can be. You'll need to monitor CSI and try to keep it neutral. But that's far in the future at this point.
    That said... if the well water is high in CH, replacing water isn't going to gain you much. Better to try to harvest as much rainwater as you can when you can. Also, when you start clearing the swamp, the filter is going to load up and need backwashing frequently, so you'll replace a few inches that way, which will also reduce CH.
    So... test pH, TA, and CYA. If CYA is too high, you have a valid reason to drain somewater. If okay, adjust pH and get to work killing algae. Pool School - SLAM - Shock Level And Maintain
    Jun 2015
    Southwest, Oklahoma
    8
    Yes, CH is 750 (not my math but my fast fingers). It is lower than usual because of all the rain we've had. It surprised me as it was 950 last fall. I hadn't run across SLAM so thanks for the link. I'll get the rest of my tests since the CH didn't scare anyone. I was afraid you'd tell me to forget it and go to the community pool! I will sleep so much better tonight knowing I can take action tomorrow. Sleep well.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    Jun 2015
    Southwest, Oklahoma
    8
    Pool is now crystal clear and I have had Cyanuric acid crystals floating for several days (although it's not dissolving very fast in the sock in the floater). I have some numbers (if I did this right. Please forgive me if I seem dumb about this but I really am. Following some of the directions is confusing but here's what I've got so far.
    FC 9.5ppm
    CC 1.5
    PH 6.8-7.0
    TA 70ppm
    CH 750
    CYA 30
    We are vacuuming sediment from the bottom but water is clear. What I need to know is (since it's now 101 deg here) is if it's safe to swim!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    LOL! You'll get there. Looks good from here!
    It is safe to swim when:
    PH is 7.2 to 7.8
    Chlorine is above minimum for your cya
    Chlorine is below shock for your cya
    Water is clear
    Chlorine CYA Chart
    sounds like pool time!
    Jan 2014
    Buckeye AZ
    807
    If you're CC is 1.5, you haven't cleared all the hurdles yet. You can swim, but keep that FC near the shock level until you pass all 3 SLAM criteria.
    Jun 2015
    Southwest, Oklahoma
    8
    Ahhhhhhhhh, what a relief it is. AC is on the blink so this is the coolest I've been in a while.
    Thanks, BuckeyeChris. I knew it wasn't right on yet but needed to, um, vacuum debris from inside the pool to reach it all. So I keep working with the bleach and Cyanuric acid to do that? I'll go back and read some more. My internet provider was down for a couple of days and then your site was down for a day and I didn't get to "study" my lessons. No problems now so I can get that done. Thanks again.
    30,403
    Site is back up! Hit the books!
    Seriously, you are doing great. read "The ABC's of Pool Water Chemistry" up in Pool School. That's sort of the cornerstone. Get that article mastered and you are on your way.
    Jun 2015
    Southwest, Oklahoma
    8
    Will do, duraleigh!!! Who knew I'd become a water baby in my 60s??? And you guys are really raising the quality of my retirement. Can't thank you enough.
    DFW, TX
    24,450
    Better late than never!
    Next you will need a hot tub for winter! Uh-oh.
    Jun 2015
    Southwest, Oklahoma
    8
    I have been basking in the success of your advise, taking regular readings and making necessary adjustments and enjoying the heck out of my pool but, the winds came, the lightning flashed, and it rained for days. I added chlorine and tested and was happy with my readings and awaiting the return of the sun while getting all the debris out of the pool that had blown in from everywhere. EEEEEEEEk!!!!!! While removing leaves and grass debris from the pool I saw hundreds of little (and some not so little) water bugs. I've fished out some and squished them (didn't want them sneaking back in) but there are more every day!!! What can I do to kill the little buggers. There seems to be a couple of different kinds. I don't know where they came from but they can't stay here!!! Help!!!!
    Jul 2015
    Clearwater, FL
    83
    I get gnats in my pool. When that happens, I push the pump to full speed so the skimmer will collect more of them and drag a fine mesh net around the pool. Taking them out with a net is probably a better option that pesticides.
    16K gallon IG exposed aggregate pool with Aquarite SWG T15 cell, Hayward C1750 filter, EcoStar SP3400VSP pump, H400FD pool/spa heater, Polaris PB4-60 booster pump, 280 pressure cleaner, Hayward Super II spa pump and Air Supply Silencer spa blower
    Jun 2015
    Southwest, Oklahoma
    8
    These are not gnats! They are water bugs. They don't float on top of the water...they are swimming around...sometimes very fast.
    Jun 2015
    Waco Texas
    79
    I had water boatmen in my pool. I used a 5 gallon bucket filled with water and a layer of cooking oil on top to smother them. That was the only way to get rid of them. They have not come back.
    Intex Ultra Frame 18 x 48 Vinyl
    6500 Gallons
    Krystal Clear Filter Pump
    with 1,500 gph (110-120)
    Casey's Avatar
    SW PA
    10,422
    You can raise your FC level by a few PPM or you can add borates to your pool.
