Results 1 to 15 of 15
Thread: Pool moving water
    Jun 2015
    Danville, Alabama
    9
    Pool moving water
    My pool moves water great on recirculate setting, but once I put it on filter it barely moves any water. There is no pressure gage on my filter. What could be wrong?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool moving water
    Welcome to TFP!
    What kind of filter do you have?
    Jun 2015
    Danville, Alabama
    9
    Hayward
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Sorry, he means type. Sand, DE, etc.
    Essential Links:
    Jun 2015
    Danville, Alabama
    9
    Oh. Sorry. It is a sand filter.
    Jun 2015
    Danville, Alabama
    9
    I have back washed the filter. I have also sprayed sealant around all the joints in case of leaks. There is not even water moving through the glass "eye"
    SW Indiana
    9,199
    How long are you backwashing?
    Jun 2015
    Danville, Alabama
    9
    About a minute after water is clear.
    SW Indiana
    9,199
    Quote Originally Posted by jencarter14 View Post
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    If the total time isn't in the 3-4 minute range, I'd consider backwashing that long. If you are already going that long or it doesn't help, you may want to follow the Deep Cleaning Your Sand Filter process.
    Jun 2015
    Danville, Alabama
    9
    Ok. I will try that. Thank you
    Jun 2015
    Danville, Alabama
    9
    Shocking Pool
    Should I keep the pool setting on recirculate after adding shock to kill algae or keep it on filter?
    38,370
    Re: Shocking Pool
    Usually you should leave it on "filter" as you have to get it all out of the pool eventually.
    Are you following the ShockLevelAndMAINTAIN Process using liquid chlorine? I get nervous when a newer member uses phrases like "adding shock" and "shocking the pool"
    I merged your threads since they appear to be related.
    Jun 2015
    Danville, Alabama
    9
    My response disappeared. I am new to this forum, so I am not familiar with the SLAM method. I typically only use shock chemicals at the very beginning to open the pool and then maintain with liquid bleach and baking soda. Unless I get too busy and let the pool get away from me.
    38,370
    So read the the SLAM process article ... in fact you should review a few things, but you need to get out of Tapatalk:
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jun 2015
    Danville, Alabama
    9
    Ok. I will get on the internet and do some reading.
