Results 1 to 19 of 19
Thread: Converting a Hayward 320 Chlorinator to dispense liquid chlorine
    Jun 2015
    Central, NJ
    566
    I am new and this maybe a silly question but here goes. Has anyone tried to convert a tablet chlorinator to a liquid dispenser. When I had a garden I used a device to add fertilizer to a sprinkler system using a venture tube and regulation of orifice to dispense correct amount. I have a Hayward 320 which I am not going to use for pucks and thought maybe it could be used for maybe a few days worth of liquid chlorine. Sort of a poor man's pump.
    I am new and trying use this year to figure out the best/most convenient system to use. I do not want to go out and buy a pump only to decide to switch to SWG.
    27,000 gals (20 x 40), IG, vinyl, Hayward Sand Filter S244T 300LB, Hayward
    Super pump SP 2607X10 1 hp.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Converting a Hayward 320 Chlorinator to dispense liquid chlorine
    Even if it were a good idea (I don't think it is, generally not a good idea to re-purpose a dispenser for one chemical to another, even different types of chlorine) I believe you would quickly tire of opening it, filling it and letting it go.
    Before I got the Stenner Pump I just went out each morning and poured in my pools daily ration of chlorine.
    Support the site
    Jun 2015
    Central, NJ
    566
    Been having difficulty getting on site due to server problem, sorry for delay in my response, thank you for your advice, I am considering getting a Stenner pump or switching to SWG. I like the idea of slowly dosing as opposed to once or twice a day to keep FC at a constant low but safe level. I am very new to pool management, never owned one before and trying to do my research before I spend money then change my mind as to the best way to go.
    May 2014
    Franklin, NC
    9,184
    Last year I was in your place. I looked at both SWG and Stenner and went Stenner.
    Support the site
    Mar 2015
    Sugar Land , TX
    424
    With a Stenner you can low dose several times a day. If you have a pool automation system or a programable timer you can low dose several times per day. This is what I do and it seems to keep FC level rather than peaks and valleys.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    One of the issues will be the residue left over in the chlorinator and adding liquid bleach. Not a good idea. No matter if you are going with liquid or a salt chlorinator, consider and sensing system that will put the chlorine in the pool only when needed.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2015
    Central, NJ
    566
    Not at all familiar with auto sensing systems, any recommendation where to start?
    JoyfulNoise's Avatar
    May 2015
    13,176
    Quote Originally Posted by Hayward Pool View Post
    This looks like a SPAM account.
    Quote Originally Posted by Pool Amateur View Post
    Be very careful with ORP automated system (Hayward Sense&Dispense and Pentair IntelliChem). You'll not find a lot of good things written about them here in TFP and they are notoriously tricky to keep properly functioning and calibrated.
    Matt
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Not hardly. This guy worked for Hayward and is now retired. His comments and advice in public forums and in private messages and phone calls are excellent.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    May 2015
    13,176
    Quote Originally Posted by JayBauman View Post
    My bad then and I apologize.
    The signature line looks totally SPAM-like
    Matt
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hayward pool has been a contributing member here for some time. He's been very helpful to many members of TFP since he joined, and he's given a little latitude as a result of his helpful contributions.
    Essential Links:
    May 2015
    13,176
    Quote Originally Posted by Patrick_B View Post
    Understood and I apologized in my follow-up post for jumping to conclusions. Since it was an honest mistake on my part, it would not bother me in the least if the mods deleted my post that made the SPAM assertion. I could go back an edit it as well but I'm not sure if that is proper.
    Matt
    Jun 2015
    Central, NJ
    566
    Thanks Hayward Pool. Can you make some suggestions as to a good sensing system that is automatically communicating with a dispensing system. From what I have read the chlorine sensing systems available are temperamental and require a lot of maintenance. I am looking at automatic dispensing systems such as steener pump and SWG but trying to educate myself before making a significant purchase. I am new to owning a pool and do not know much, and have been told many things that are incorrect and made some poor decisions. In the interim I need to have a dispensing system as I can not be at the pool enough to correctly maintain manually. At present my CYA is at 40 and I am using trichlor in the 320 chlorinator and as I start to reach 60 will have to pump out water. But until I decide on the best system for me I think this is best unless I can rig up a temporary system that is fairly cheap and willing to toss when I decide on the best system. As for the chlorinator 320 what are you talking about when you say "residuals left over in the chlorinator" I do not understand. This may best be taken care of by starting new thread but I do not know how to do that and still contact you. I am still trying to find out how to be notified when someone comments on my threads but again that is off topic also.
    Jun 2015
    Akron Ohio
    23
    deleted
    30k IG concrete and fiberglass, 1HP Hayward Superpump, Pentair FNS plus 60 DE, Polaris 180, Taylor K2006 with TFTestkit refills, Stenner pump
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by rynd96 View Post
    With the 320 already installed it makes the Stenner option really easy. I installed mine this weekend, took a couple of hours and that included multiple trips to my tool box and some thinking. There isn't much that could go wrong, if it does, repairs are cheap and easy. Plus you can still use pucks at the beginning of the season to get your stabilizer up.
    See my install http://www.troublefreepool.com/threa...787#post863787
    Mixing pucks and liquid chlorine in the feeder is a bad idea, very possibly a dangerious idea.
    Support the site
    Jun 2015
    Akron Ohio
    23
    deleted
    38,251
    I agree with Tim. This seems like a REALLY bad idea where there is much too high of a possibility to accidentally run both types of chlorine with catastrophic results.
    I do not think I am out of line by saying that TFP would NEVER recommend this!!!
    May 2015
    13,176
    If you're looking for cheap and simple, try out Mark's (@mas985) idea -
    http://www.troublefreepool.com/threa...jection-System
    It's relatively cheap and easy to setup and doesn't require ripping out any existing PVC.
    Matt
    Oct 2014
    Elizabeth
    426
    Mixing any chlorinating chemicals can be dangerous. I can tell stories. I am retired from Hayward but still do consulting work for them like monitoring social media. Yea a 68 year old guy who likes social media, what gives. Hayward makes a Sense and Dispense unit that relies on our control systems to operate. ProLogic, OmniLogic and AquaRite Pro. I am really concerned about what you are doing and the mixing of chemicals. If you want to have a give and take Private message your phone number and I will call. Them post what we talked about.
    Hayward Pool Tech
