Thread: Quick shock question
    It appears the Pool Calculator and the Chlorine/CYA chart recommend different shock levels. i.e. 16 versus 20 for 50 CYA. Which do I use?
    18' x 36' saltwater inground vinyl pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Quick shock question
    Use poolmath instead of poolcalculator. http://www.troublefreepool.com/calc.html
    Shock level is 20.
    38,260
    poolcalculator.com is not maintained by its current owner. TFP now has a version (PoolMath) that we maintain and have made updates to some of the parameters.
    Thank you both.
