Results 1 to 8 of 8
Thread: Inground-aboveground hybrid with partial glass
    Apr 2008
    Indonesia
    311
    Guys,
    Anyone out here with experience on a pool installed with glass. Yes, glass not Sea World type of arclylic.
    This is a friend's pool.
    Fixing glass on the deeper side of the pool is not a 100% success.
    There is always some leak, very minor but a leak is a leak.
    The difficulty is getting a sealant that will stick well on stainless steel, steel, concrete and glass.
    I have been training his pool boy on BBB method and so far so good.
    I know sooner or later ( maybe next 2 years max ) the glass has to be re-assembled and the steel support need to go away and repaced with stainless steel and better sealant.
    When it was first built, I tried to get involved on the calculation of the glass part of the pool since I worry that it will break.
    I found a calculation method on the internet by some aquarium guy and cross check with a local glass factory and finally I decided to get my friend to install a last minute middle support pillar instead of having the glass so wide apart. Having the glass wider a part is the risky part. So instead of 3 pieces of glass, it became 6. Better safe than sorry.
    At one stage I heard a supplier doing arcylic made a quotation and he wanted US$200,000 just for 3 pieces of arcylic complete with special frames, all made in USA. It was just too expensive.
    The last minute pillars ( white color, 3 of them ) are made of steel is because getting 316L stainless that size was difficult to source and so it was decided lets test the glass with epoxied steel frame for the middle pillars.
    This is a concrete pool.
    Thanks in advance.
    SPP
    35,000 GL pool. In Ground. Concrete with all white ceramic tiles. Outdoor but shaded.
    Approx 36 ft by 15 feet. 2HP Hayward Super Pump, Hayward Sand Filter with Zelbrite ( Zeolite ), Hayward Cartridge Filter, Aquamatic Silver+Copper Ionizer ( suspended use since Oct 2008 ), Prozone Ozonator, 2 gram/hr, Analog Flowmeter on pipe
    Back Up Pump & Filter on trolley, Pentair 1.5HP + Pentair Cartridge Filter, Slime Bag 1 micron Jumbo Size, downstream of Cartridge
    Apr 2008
    Indonesia
    311
    Re: Inground-aboveground hybrid with partial glass
    This is the early stage.....sorry all photo not too good, I used my mobile phone camera.
    Apr 2008
    Indonesia
    311
    traces of initial leak
    Apr 2008
    Indonesia
    311
    The intention of the glass being installed was actually for my friend to be able to watch his kids dive and video them from outside. So no need underwater camera.
    The second intention is for us to practice target shooting with our speargun and able to video it easier from outside.
    However there is a mistake here. The glass is made also as part of the overflow. When water overflow on the glass, the vision is distorted and stain build up on the glass, the outisde part when the water get dried up....
    This is a double laminate glass of I think 4 cm thick or so, I can't remember.
    Apr 2008
    Indonesia
    311
    What else is a problem with this pool....
    01. Leaking water inlets fitting, loosing water.
    from-where-is-my-pool-leaking-t10295.html
    02. Poor surface water movement in the kids pool ( the smaller pool ).
    The pump room is below the deepest part of the pool. At least 6 feet deeper, I mean the position of the impeller housing.
    The pool uses two pumps. One pump feed the left side water inlets of the deeper adult pool.
    The other pump feeds water inlets below the glass ( 3 of them ) and all water inlets on the kids pool.
    The pressure loss on the kids pool is greater due to distance and those water inlets being much higher than the adult pool, so it makes waterflow so weak in the kids pool. The bad effect is that the kids pool water surface does not move fast enough to send the airborne dust on water surface to the overflow. The overflow is the entire left side of the deep pool and the glass part, that's it.
    So what I did is, use the pump which is supposed to be dedicated for the vacuum robot, set the suction to be sourced from the deeper pool and the discharge into the kids pool. At the end of the discharge, I placed the 1 micron Jumbo Slime Bag. So aside from having surface water movement, the water gets fine filtration too. It just a bit ugly having a Jumbo Slime Bag everday in the kids pool.
    revstriker's Avatar
    Apr 2008
    Texas
    117
    That is quite an amazing and cool looking pool! I'd be so scared of that glass breaking if it were me. But it looks great!
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    That is really amazing. I cannot imagine having it in Texas- what a nightmare it would be trying to keep it clean and keep stuff from hitting it in high winds. But WOW!
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Apr 2008
    Indonesia
    311
    Hello guys,
    Glass is strong , no worry. The weakness of glass is on the side. I seen how one does a "cracked" glass table.
    3 layers. Normal + cracked + normal glass. Juts take a light weight metal hammer and hit the glass side and being a temepered glass...the crack forms nicely....
    Cheers
