Thread: walls bowing
    Jun 2015
    tennessee
    1
    walls bowing
    We are installing a 30 ft round pool. We are to the point of filling and realized that the beaded liner that we have has a lot of stretching to do to fit. We have about a foot of water in it now and it is starting to bow the sides of the pool in a couple of places. Is this normal or should we be concerned don't want to colapse the pool.
    PaulfromCT's Avatar
    Sep 2013
    Connecticut
    27
    Re: walls bowing
    With a beaded liner make sure you fill (slowly at first 24") during the day under a HOT sun. Our pool walls bowed a little bit at first but eventually the water pressure equalized everything. If we had used a pool water delivery truck our pool would have most definitely collapsed when fast filled. Next time I am doing an overlap liner---less stress with the fill. Good luck with the pool
    24' X 54" round AGP with Uni-Bead Portofino Liner - 25 Gauge, partially in-ground. Hayward Perflex EC-40 D.E. Filter System 1-HP Power-Flo Pump. Installed Spring 2014.
    Casey's Avatar
    SW PA
    10,446
    Re: walls bowing
    It is normal but don't fill at night like Paul stated. It needs filled under the hot Sun.
