Results 1 to 10 of 10
Thread: Cooler Pool
    May 2015
    Houston TX
    49
    Cooler Pool
    Our dig is scheduled for tomorrow. Just talked with my son who has a pool in Georgia. He says the only problem they have with their pool is the water is sometimes too warm. Is there anything, outside of installing a chiller, we can add to the pool to help keep the water cool ? Do water features help ?
    Also, does the pool finish color ( we are using Wet Edge ) affect the water temperature?
    Houston,TX, IG 15120 gal, gunite, 22' x 36',wet edge finish, Pentair equip, 420 cartridge filter, vs pump, Intelliflo vs booster pump for water features, 400,000 heater, auto fill ,PCC 2000 in floor cleaning ,2 LED lights,travertine coping, paver decking, 9x12 tanning shelf ,1 LED color bubbler, 2 5' benches w jets. Depth 4- 4 1/2- 5 , wall with 3 24" sheer decent , 2 spray heads, Intellitouch Controller.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Cooler Pool
    Deck jets run in the early hours of the morning will drop the temp of a Houston pool a few degrees.
    The longer the arc the more heat transfer/evaporation.
    I thought the humidity here would stifle this effect but it absolutely works.
    I am hoping that running my waterfall for a couple of hours pre-dawn will have a noticeable effect on mine.
    Until it gets hot I can't really test the this method.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Cooler Pool
    Yes, running water features overnight will lower the temperature. So will running solar panels at night. Running water features will also raise your PH, so keep an extra eye on it. Darker colors tend to make pools a little warmer.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Re: Cooler Pool
    Deep pool, light plaster, shade on pool, spraying water, no spa.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2015
    Houston TX
    49
    Re: Cooler Pool
    Well we won't have a deep pool, but hopefully the jet sprays and waterfalls will help. May choose a lighter Wet Edge finish. We moved here from Virginia, so Texas heat is something we're trying to get used to. Thanks for your help !
    DFW, TX
    24,485
    Re: Cooler Pool
    The pool makes the texas heat all better! Get hot, jump in pool, repeat.
    Mar 2015
    Las Vegas NV
    460
    Re: Cooler Pool
    Quote Originally Posted by magicruiser View Post
    After speaking with several neighbors regarding water temp who have white plaster pools and one with a darker plaster we decided to go with a lighter quartzscape, something called "blue". So far we really like it, also like the fact that the LED lights seem to be putting out true color on it. Glad we went with a lighter quartzscape vs. just plain white, seems to make it pop a bit.
    It can get a bit warm here in Vegas and the last thing I wanted was to climb into a warm pool on a 110 degree day.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Cooler Pool
    See my reply to this poster. It is near the end of the post. Cheap and effective.
    Pool Temp too hot!!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Re: Cooler Pool
    ComputerGuy: What's the name of the brand and/or name of the fountain? Where did you buy it?
    My pool doesn't even have water in it yet, but I like pool water to be as cool as possible in the summer. In the 70's would be great, but I realize I'm going to have to settle for lower than what it is without any devices!
    Thanks!
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Oct 2012
    604
    Re: Cooler Pool
    Suz, I got it off amazon. I am thing about getting a second one before it gets real hot in Louisiana.
    Amazon.com : Flower Swimming Pool Fountain : Swimming Pool And Spa Parts And Accessories : Patio, Lawn Garden
