Thread: Water leaking around skimmer hose connection
    Jun 2015
    Flemington New Jersey
    6
    A small amount of water leaks from the skimmer hose connection when the pump is off but stops when the pump is on. The pump doesn't completely prime . What could be the problem? Any ideas?
    15x30 oval above ground pool; hayward 1 hp power flow matrix pump; sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Water leaking around skimmer hose connection
    I'd say you found your suction side air leak.
    Plug the skimmer with a cork or a rubber stopper or a potato whittled down to size and remove the hose and check for any cracks on the skimmer. Then look at the hose. Maybe it's cracking internally or the clamp is stripped.
