Thread: what should be my target cya?
    May 2014
    Gaffney, SC
    16
    UPSTATE SOUTH CAROLINA WATER TEMPS HOLDING AROUND 88 - 90
    LOSING 3ppm FC daily. Seems like more than last year. Have had to add a little water several times this season. What should my target CYA be?
    Thanks in advance
    FC6
    CC0
    PH7.5
    CYA35
    TA70
    13.5 k gallon, AG Swim n' Play Inc. Islamorda 24 ft. round , Pentair Dynamo 1.5 HP Pump, Pentair Sand Dollar SD40 sand filter 40GPM.
    Install 5/20/14
    Jun 2014
    15,093
    Re: what should be my target cya?
    Hello Cosmic! The CYA range for a non-SWG pool is 30-50. So if you believe your water is otherwise healthy, and by that I mean no excessive loss of FC, OCLT and water clarity okay, then sure, many people will go up slightly on their CYA - maybe 40 or 50. In my region, I just bumped mine up as well.
    Also keep in mind that factors such as pool size and amount of activity can justify a loss of 3 ppm. Hope that helps.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    3ppm is not a lot. But, nothing wrong with raising CYA another 10ish.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Cosmic Charlie how do you do. We also have a "ship of fools" here too. Welcome
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
