Thread: Pentair intellichlor ic40
    Jun 2015
    Macon
    1
    None of the lights on the cells are lighting up. Help!
    38,262
    Re: Pentair intellichlor ic40
    Welcome to TFP!!!
    Does it have power?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Welcome to TFP!
    Please add your pool info to your signature as shown here, Pool School - Getting Started
    Here are all the things I can think of:
    Power is out
    Breaker is tripped
    Power cord is cut to power module
    Cord is cut from power module to IC
    Cell has failed
    Power module has failed
    Do you have pool automation controlling the IC?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Could also be a blown fuse. There is a fuse holder on bottom of the power center.
    If its in a timer or controller of some sort, make sure that's working.
    Divin Dave,
