Results 1 to 9 of 9
Thread: Brain dead new to pool ownership
    Jun 2015
    NORTH PLAINS
    4
    I have a intex above ground vinyl pool
    4800 gallons
    Alkalinity of 100ppm
    cl Br .51
    PH 8.2
    hardness 100ppm
    temp is 64
    I want to use the BBB method. I went to use the online pool calculator but have NO CLUE as to what I am doing.
    HELP! Seriously Frustrated!!!!!!
    9x18x4 vinyl above ground
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Brain dead new to pool ownership
    Welcome to TFP!!
    Well, first I would ask where you got those numbers? Pool store? Your very own test kit? If you kit, which one?
    Support the site
    38,271
    Welcome to TFP!!!
    That Cl number seems odd and I do not see a CYA number that is very important.
    Jun 2015
    NORTH PLAINS
    4
    It is a hth kit I picked up from Walmart Just following the instructions provided
    38,271
    Is this a fresh fill? Or how does the water look?
    You either need to follow the Pool School - Guide for Seasonal/Temporary Pools or you need to invest in one of the Recommended Test Kits
    Jun 2015
    NORTH PLAINS
    4
    oops lol l is 5 Br is 1 the bottom of the tester chart
    Cl not l is 5
    I filled it just about 2 weeks age with well water
    don't know how to get cya. I live 35 miles from town and what I have read so far is a pool store has to test for that number
    38,271
    And what have you added to it in the last 2 weeks?
    You do not have Bromine, so ignore that column.
    Um, you did not read anything on this forum suggesting you to have the pool store test your water. We do not trust pool store testing. You either need to order a better kit or follow the Temp Pool guide I listed above.
    Jun 2015
    NORTH PLAINS
    4
    Oh and the water is just starting to turn green
    Thank you all so very much!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,448
    You need to let us know which way you want to go with your pool so we can help you get it cleared.
    You are about to have a mess of algae on your hand. We can help you get and keep it clear.
    Kim
