Results 1 to 9 of 9
Thread: AGP Padding
    Jun 2015
    Tacoma/wa
    10
    AGP Padding
    Moderator comment: This post was separated out from this thread: 32X16X52 Intex Rect Pool - Paver spacement/measurements
    Quote Originally Posted by zaxs View Post
    I went with the 1/2 in padding. Did you find that the measurements are a little off in that table? If I was going to start over I would have laid the foam padding at 12X24 and butted the pavers right up to the foam padding. It would have saved me a lot of time laying out and squaring off the area with lines. I took a lot of time putting down the layout lines so that the measurements of 13'10" and 25'10" would put the legs right in the middle of the pavers but they are off from center about 2 inches. And according to the table the bottom of the pool is 12X24 and that isn't even close as I can see but I only have about a foot of water in the pool so far.
    I just purchased an intex rectangle pool and wondered about the foam padding you put down. Was it a stiff foam insulation or was it a soft type of padding you used?
    Thank you
    Jun 2014
    15,070
    Re: AGP Padding
    Hello and welcome to TFP! It looks like you haven't received a reply yet on your post about padding. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    Jul 2014
    Oakbank, Canada
    389
    Re: AGP Padding
    Everyone uses hard foam sheets, not soft.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2015
    Tacoma/wa
    10
    Re: AGP Padding
    The hard form insulation padding? I was worried it would dent but I guess with all the water weight it would already be compressed.Thank you. I'm sure I will make many mistakes but trying to reduce them. Never had a pool before. Grandkids are excited.
    New Intex 24x12x52 above ground pool.Rich
    FunFinder's Avatar
    May 2015
    Cajun country, Louisiana
    115
    Re: AGP Padding
    I used this pic as my guide: image.jpg worked great. The guy doing the taping took off his shoes. No dents whatsoever. I love how smooth the bottom of our pool feels. So nice of you to put up a pool for your grandkids!
    Intex Ultra 9'x18' AG, 2800 Gph .75hp pump, 77# sand filter, Intex ECO SWG, Hayward wide mouth skimmer, KK Lil Shark vacuum, Intex magnetic light, TF-100 w/ SpeedStir
    Jun 2015
    Tacoma/wa
    10
    Re: AGP Padding
    Thanks Funfinder. Just finished leveling the ground. that was a weeklong adventure doing myself as our back yard was really sloped. I was also wondering if you compensated for the 3/4 inch foam thickness with what your support legs are resting on. Meaning, if you added the 3/4 inch foam, did you raise the support legs that much as well, or leave them flat/level with the ground and assume the pad would compress enough?Thanks
    FunFinder's Avatar
    May 2015
    115
    Re: AGP Padding
    I just put the wooden boards level with the ground, seems to be working well so far. I used the wooden board method specified in the install book, but could not find boards 15" wide, so I use two 8" wide boards under each leg, so I have a 16x16" square. Now the hard part is over! Let the fun begin! Did you get the pool up and filled?
    Jun 2015
    Tacoma/wa
    10
    Re: AGP Padding
    Finally done and used for about a week now.20150621_130226 (2).jpg20150707_202933.jpg
    finished product
    FunFinder's Avatar
    May 2015
    115
    Re: AGP Padding
    Looks great! Enjoy!
