Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Filling up Pool
    Jun 2015
    Bedford hills ny
    46
    Filling up Pool
    Hi guys. I am filling up the (very) old pool at my new home for the first time with water from our well.
    It is a 45k gallon, plaster, ig pool with a Hayward salt water system and a Hayward de filter.
    We are a few days into the process of filling it.
    I will try the sock method and drop granular stabilizing chlorine in and the add (I guess based on reading) a gallon of bleach a day.
    My test kit and and granulated chlorine arrive Weds. I can start adding bleach as early as today.
    I expect it to take most the week to fill it.
    Do I need to slam it after that?
    20' x 50' AG gunite pool (no idea on gallons) built a long time ago. DE Filter w/Hayward Pump. Well water.
    38,301
    Re: Filling up Pool
    If you keep some FC in it as it fills, there should be no reason to SLAM a fresh fill.
    Do you have metals in your well? Might keep an eye out for iron discoloring the water.
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    I do have iron. Pray for me.
    38,301
    Re: Filling up Pool
    Well, hopefully it will filter out.
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    Yes. Although I am a few days from being able to filter. Thank you.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Re: Filling up Pool
    make a bucket filter. there is a thread about it here somewhere. a youtube video or two also. if i remember correctly, you poke holes in a bucket and fill it with fiberfill like for making pillows and stuff. then you run your hose into it. it should take out some of the iron before it can get into the pool. there is a hose attachment you can get too.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    Awesome. Thank you
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    One more question:
    I have a Hayward SWG. Do I start with bleach or salt in the pool?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Filling up Pool
    Start with PH and then CYA in a sock and bleach. You can add salt too, brush it some and give it 24 hours to dissolve before turning on SWG.
    Here are the target level for a SWG pool.
    http://www.troublefreepool.com/conte...rine-generator
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    Thank you very much
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    I did my first test last night.
    No chlorine, No CYA, ph 7.0, alkalinity of 70.
    Then I dropped 3 socks with granulated chlorine on floaties in the pool and poured in a big jug of Clorox.
    Looking fwd to taking another reading this AM.
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    Test 2
    FC 0.6ppm
    CC 0.2ppm
    Ph 7.0
    TA 70ppm
    Calcium Hardness 100ppm
    CYA less than 30ppm
    Salt
    DFW, TX
    24,497
    Re: Filling up Pool
    With TFPC we prefer to be more precise with our chemical additions. Use Pool School - PoolMath to determine how much to add.
    Do you have one of the Recommended Test Kits? I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School articles to read up on
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    I have the Taylor k-2006.
    I used the pool calculator to determine how much granulated chlorine to use (177oz).
    I wasn't going to add the rest of the chemicals until I get a few more inches of water in and can run the filter.
    DFW, TX
    24,497
    Re: Filling up Pool
    Good deal! How deep is your pool? There is a pool volume calculator toward the bottom of poolmath to calculate how many gallons your pool is. Your sig says no idea.
    20x50x4 is 30k gal
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    I will change that. It's somewhere close to 44k gallons.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Filling up Pool
    When you say granulated chlorine, exactly, what is it?
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    Stabilizer.
    I was reading another thread about filling a pool and followed the basic instructions from it.
    Jun 2015
    Bedford hills ny
    46
    Re: Filling up Pool
    Ok. Reading 3
    Water is 66 degrees
    FC is back to 0
    CC is back to 0
    PH is still 7.0
    TA up to 80
    calcium Hardness down to 80
    CYA still below 30
    A few questions:
    1) I have had socks with 188 oz of stabilizer in the pool for almost 48 hours. But they don't appear to have dissolved much.
    2) I have a SWG and bags of salt. How do choose a mix of salt and bleach?
    3) how do I convert concentrated bleach to the right volume of 6% bleach
    4) pool isn't entirely full yet so I won't turn the filter on until tomorrow. Should I add all the chemicals now or wAit until I am full and running?
  20. Back To Top    #20
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Re: Filling up Pool
    1 you are squeezing sock every once in a while.
    2 wait on salt and SWG until you're full and balanced.
    3 change poolmath to match your bleach concentration.
    The experts will probably be along soon.
