Results 1 to 10 of 10
Thread: Intex 1,500 gph (110-120V) model 635 replacement
    Jun 2015
    Nashville TN
    17
    I've got a pump that after a season doesn't pump well at all. My pool is the Intex Easy Set 18'x4' AGP. I've bought an Intex Salt filter and with that inline the filter pump is just not working well enough for the salt water pump to produce chlorine fast enough to keep the pool chlorine at an acceptable level.
    I'd spend more money for a quality pump that actually worked and would fit my existing pool.
    Any recommendations???
    Thanks
    Harry
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Intex 1,500 gph (110-120V) model 635 replacement
    Is the SWG alarming with a low flow indicator? What makes you think it is not producing chlorine fast enough? SWGs either produce chlorine or they don't. There is no in between.
    Mark
    domct203's Avatar
    Jun 2015
    CT
    3,592
    While I don't have a SWG, I use the 14" 2150GPH Sandfilter system and it does a great job. I run two 3-1/4 hour cycles for two turnovers a day, that combined with TFPC gives me the clearest pool I've ever had.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    How did you determine it doesn't flow enough? Low flow in the return to the pool? Low flow lights on in the SWG?
    Any chance it's just that your filter needs cleaning? Is the pool green and/or cloudy? That will both load up a filter in a hurry and consume all the FC you generate as fast as it hits the pool.
    Jun 2015
    Nashville TN
    17
    yes the chlorine had been good a week before and now registers 0 AC. The skimmer basket doesn't pull enough to suck water over the brim, we've put in three filters in three days. we keep having to bleed air out the top of the filter pump combo. With a new filter and freshly let air out and it pulls better but I don't think anywhere like it should.....I know the Intex pumps have a rep for being cheap and only last a year or so and wondered if anyone else had changed out -
    the salt barked about low flow only once and it was dirty filter. And many times for high salt warning though the pool tests at the pool store are registering low salt. My theory is the low flow is causing the salt to seem concentrated but i'm no expert.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Sounds like you might be having an algae bloom. That will clog up the filter and reduce flow rates.
    Also, if you are getting a lot of air into the filter, then you have an air leak somewhere on the suction side of the pump that needs to be fixed. How is the water level? Make sure air isn't getting sucked into the skimmers.
    Mark
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Check to make sure there isn't a clog somewhere. It's been a while since I had that pump, but I remember finding hair and grass stuff somewhere, causing low flow.
    Richard320's Avatar
    Jan 2010
    19,037
    Pine needles in the impeller can cause low flow conditions. Shouldn't cause air in the tank, though.
    Jun 2015
    Nashville TN
    17
    no pine trees around here. "Sounds like you might be having an algae bloom" so I can brush the bottom four hours ago and see blue pool bottom but jyst went out and totally green on the floor again - is that an algae bloom?
    domct203's Avatar
    Jun 2015
    CT
    3,592
    Quote Originally Posted by lightstamp View Post
    I would think so, especially if the FC dropped below recommended levels.
    Do you have one of the recommended test kits? Can you post a full set of test results, especially the CYA.
    We need these results so you can calculate your proper shock level and SLAM that pool. In the mean-time you better get that FC up. Using pool math put in enough bleach for 10ppm. Check it an hour later and post the results.
    Dom
    Dom - TFP Guide
