Results 1 to 7 of 7
Thread: Adding CYA
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    Adding CYA
    Would it be ok to let it dissolve in a bucket and then pour in front of the return? Seems like it would be faster then the sock in the skimmer.
    30K gallon 20 X 40 IG vinyl built 8/2013, Hayward 1.0 hp super pump, 250,000 BTU Hayward heater, S244s Hayward Sand Filter w/side mount multi port valve, Hayward Aqua Rite Salt Chlorinator with Turbocell T-15 , Coverstar automatic pool cover with key switch, TF-100 test kit.
    domct203's Avatar
    Jun 2015
    CT
    3,578
    Re: Adding CYA
    Been there, it takes forever for the granuals to dissolve, even with hot water. I would use a paint mixer in an 18V drill and go thru two batteries and the stuff still wouldn't be dissolved.
    Since I started TFPC I put it in a nylon stocking hanging from the ladder, done in a few days to a week. Easy-Peasy.
    YMMV
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Adding CYA
    Dom has it.
    Generally there is a lot of experience behind the recommendations made here at TFP. But, whenit comes down to it, it's your pool to treat how you would like. To quote Dave, Site Owner of TFP:
    Throughout TFP, you will read that we suggest certain levels that good science and practical experience has taught us fall within safe ranges.
    Further reading of posts here will draw you to the inescapable conclusion that these guidelines work.......in thousands and thousands of pools worldwide.
    You may or may not choose to use these methods and guidelines or you may use some and not others. Our goal is to teach you what has been proven time and time again and then let you use that information to your benefit.
    Support the site
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    Re: Adding CYA
    Thanks for the responses I will continue to put the socks in the skimmers.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Adding CYA
    Quote Originally Posted by domct203 View Post
    YMMV
    Dom
    Love to see new people jump in with answers!
    May 2015
    River Falls, WI
    124
    Re: Adding CYA
    It's best not to put the socks in the skimmer. It is acid after all. You're better off placing the sock in front of the return or anywhere else in the pool. Aside from DE don't put anything in the skimmer, including pucks. Use floaters for the occasional/temporary usage of pucks.
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Adding CYA
    Quote Originally Posted by wrems View Post
    As long as the pump is on and the water is circulating one of the TFP recommendations is to set the sock in the top of the skimmer. Now if the pump is off then it is recommended it not be in there.
    You can read about adding stablizer in a sock to the skimmer basket on this page.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
