Thread: SWG with an autocover?
    Jul 2013
    North Canton, OH
    192
    We have a Coverstar autocover with the rails embedded in the concrete below the coping. When we built the pool, we were advised against SWG due to the autocover rails and corrosion. Does anyone have any direct experience with this? I would love to switch to SWG, but obviously do not want to damage the autocover rails.
    Thanks
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    Re: SWG with an autocover?
    I have a SWG with a Coverstar cover and haven't had any problems. I would do it again once you get your CYA right and the SWG dialed in you only need to add acid about every six weeks.
    30K gallon 20 X 40 IG vinyl built 8/2013, Hayward 1.0 hp super pump, 250,000 BTU Hayward heater, S244s Hayward Sand Filter w/side mount multi port valve, Hayward Aqua Rite Salt Chlorinator with Turbocell T-15 , Coverstar automatic pool cover with key switch, TF-100 test kit.
    Jul 2013
    North Canton, OH
    192
    bump
    is calespool the only person with experience with an autocover and SWG?
    Jun 2015
    Phoenix, AZ
    216
    I am planning to add a zinc sacrificial anode to the plumbing. Does the Coverstar track also have to be connected to the pool bonding wire, in order to be effective?
    2015 build (link)| 16.5 K gal | Salt Water | IG rect | 35'x16' | 568 sf | 105 ft peri | depth 3'-5' | PV3 in-floor | 2 Venturi skimmers | MDX+SDX drains | T-CELL-15 SWG | Hayward Ecostar VS pump | Hayward 7220 DE Filter | Aqua Cal Icebreaker Heat / Cool pump SQ166 | Hayward Sense & Dispense PH Controller| Omnilogic | Pebble Sheen Blue Surf | Ultra UV | Stenner acid pump | Coverstar Automatic | TF-100
    Mar 2007
    San Rafael, CA USA
    12,082
    The main problem with autocovers and the higher salt level is with the aluminum header bar in "vanishing" covers since that bar is partly immersed in the water. In that situation, a zinc anode buried in moist soil and electrically connected to the bonding wire would protect all metal connected to the bonding wire which means all metal in contact with the wire (if the pool is properly bonded). Your aluminum tracks and aluminum header not in the water could similarly be protected if they are connected to the bonding wire. It is probably not necessary, but it doesn't hurt.
    It's the overtracks that have the biggest problem due to splash-out as shown in this post.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    I have both a SWG and autocover for going on 3 years now. I don't see any degradation of the aluminum tracks. We do rinse them off on occasion but probably not as often as we should.
