Results 1 to 8 of 8
Thread: How to remove Thompson's Water Seal from pool water
    May 2014
    Summerdale, AL
    27
    My husband sealed our pool deck with Thompson's Water Seal and sprayed it on instead of brushing it on. Apparently, the mist of it got in the pool water. I have been running the pool pump non-stop since noticing the oily feeling in the water and on the surface yesterday. When I felt the water this morning, it still feels oily. What can I do to get the oil out or is there a product I can put in to help?
    Intex 22'x52" 10,500 Gallons AG Pool w/Vinyl Liner, Intex Krystal Clear 2150 GPH 3/4 HP Sand Filter Pump, Intex Krystal Clear Saltwater System
    Installed 5-26-14.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: How to remove Thompson's Water Seal from pool water
    If it doesn't filter out, Pool First Aid is an enzyme cleaner that eats most petroleum based stuff. Pool First Aid | Product Detail | Natural Chemistry
    Jun 2015
    N Tonawanda, NY
    477
    Would over flowing the pool do the trick?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    May 2014
    Summerdale, AL
    27
    I just added some Clorox Natural Clarifier to the water. It says to run the pump for 8 hours. I've had it running for over 24 hours already. The pool is just as clear as a bell but still has an oily feel to it. I think the clarifier is supposed to cause the oil particles to clump together and become larger so they will either filter out or go to the bottom of the pool to be vacuumed out. I will see what it looks like and feels like tomorrow morning. As far as overflowing the pool, the oil sheen isn't on the top anymore since I've been running the pump non-stop, although that could work possibly. I just don't know. I'm going to see what the clarifier does and will go from there.
    Installed 5-26-14.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I think clarifier's only work on tiny solid particles. Oil is not a solid, it's a liquid, so it will have no effect. Suggest you follow the previous sage advice of using an enzyme cleaner which is intended to break down oil based materials.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    May 2014
    Summerdale, AL
    27
    The bottle says it eliminates oils and scum so that is why I chose a clarifier and not enzymes. Enzymes supposedly would not work in this case because they only work on organic compounds, which this oil isn't. This is what I was told by a rep from In The Swim.
    Installed 5-26-14.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I find the In-the-Swim catalog a hoot to read for all the outrageous claims made for many of their products. You should take their advise with a liberal grain of salt over any of the posters here. By the way, the bulk of oils in this world are organic compounds so I'm not sure why he claims that oils are not organic. Simply Google "Are oils organic compounds?" to find out for yourself.
    May 2014
    Summerdale, AL
    27
    Thanks for the input. Since I've already added the clarifier, I will see what it does. If that doesn't do the trick, I will move on to enzymes. Thanks!!
    Installed 5-26-14.
