Results 1 to 8 of 8
Thread: Before and after
    Mar 2007
    Ontario
    211
    Before and after
    Here's a quick before and after picture.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    New Brunswick Canada
    819
    WOW!..quite the transition.....CONGRATS on your Gorgeous Backyard
    Rik
    Mar 2007
    Morris, IL
    477
    No more mowing!!!
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2007
    Ontario
    211
    Little bit , but I just jump in the pool after! Thanks for the kind words "pooladdict"!
    Mar 2007
    Morris, IL
    477
    Well, the grass you do have is nice and green. Very nice. How do you like the pavers around the pool? Do they get hot? Did you do any of this yourself?
    steve
    Mar 2007
    Ontario
    211
    I did the landscaping(complete with irragation system) and interlock myself.
    Had help with the shed. You would not believe how much hotter the pavers
    are compaired to 3' of concrete. I think are back yard is pretty hot,
    are pool has been at 82 with no heater and no solar blanket the last couple days.
    Attached Files Attached Files
    Arizona
    924
    What an incredibly wonderful transformation! You did a wonderful job.
    Wow, your backyard must be hot. I live in sunny Arizona and my pool has only been up to 82 degrees F so far this year. Last week we had a couple of cooler days where it was only in the low 90's and my water temp dropped to 76 degrees F. My pool gets full sun.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Very nice!
    the hot pavers just make that first dip into the water all the more refreshing!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
