Page 1 of 3 123 LastLast
Results 1 to 20 of 57
Thread: Help with CYA and comparing to Standard!
    May 2015
    Cincinnati/ohio
    30
    Like many others I too am very frustrated with the CYA test. I feel like I am improving but to be sure I ordered the Standard to compare. I can still see the dot!!! I thought it should completely disappear!
    Comparing the 50 ppm standard to my pool water tube I am measuring 80 ppm with my pool water. However I feel comfortable saying that with my pool water tube the dot pretty much disappears closer to 60. I know responses with say to go with the standard but why can I still see the dot. Its a bright sunny day.... back to sun... tube at waist level. And yes I have poured and repoured. If I move to more shade the dot is even more evident.
    I would love to believe my stabilizer is at 80 because that would be perfect for my swg. But if it's 60 I need to add some. If I'm wrong and it's really 80 then it will be too high! What do I do?
    18K gallons Vinyl IG, SWG, Sand filter, installation completed 5/2013
    TF-100 test kit user
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Help with CYA and comparing to Standard!
    i'm not understanding what you saying. What is the measurement where the standard solution completely obscures the black dot? Is it 50, 40, 30 or never?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    By the way, and it's embarrassing to admit, but on 2 separate occasions, I poured the 50ppm Standard Solution directly into the viewing vial, thinking it was pre-reacted or a concoction that simulated the effect. It was crystal clear all the way to the top, and I was going to call TFT to find out why it went bad so quickly. Duh...finally figured it out that I had to add the R-0013, before I made that embarrassing call.
    38,251
    Yeah, I am thinking the standard solution may not be used correctly. It is used in place of the pool water and you still add the CYA reagent.
    May 2015
    Cincinnati/ohio
    30
    I absolutely used it correctly. I used in place of my pool water and mixed with reagent. Filled it to 50 because that's what it should be. I still feel I can see the dot.
    May 2015
    Cincinnati/ohio
    30
    Quote Originally Posted by gtemkin View Post
    It's a 50 ppm standard so it should disappear at 50 but I think I can see it. It's obscured but not gone. Using it to compare the tube that has my pool water mixture they look the same when my pool water tube measures 80. But again I don't feel that's following the instructions.
    There's gotta be a better test. If it's so important to get your cya correct it seems like the test should be less subjective.
    38,251
    If there was a better test, we would use it.
    You need to adjust the way you look at the test so that the standard solution gives you 50. That is the point of it. Your lighting conditions are not correct if you still see the dot.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Lighting is a very much a major player. In other posts on this subject, others have pointed out that reflections in the meniscus can confuse the eye into thinking there's still a black dot. Not saying that's the case here, but I wanted to throw out the possibility.
    Mar 2015
    Sugar Land , TX
    424
    I think this test can play tricks on our eyes. Now this is not scientific but ..You know how if you stare at something then look the other way you can sometimes keep seeing that object. If you look on the Taylor page about CYA test they have some photos of the test from start , mid, to finish. Try staring at the start then the mid. Then look at the finished photo and you can still see the dot, or our mind thinks it see's the dot. Now if you look at the photo's quickly it seems the dot is gone in the finished photo. I noticed this the other day when I did a test. The longer I looked at that dot it seemed to never go away but was VERY faint. I tried to just quickly do the test and it seemed more definitive to my eye's. Thought's on this non scientific way to look at it?
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by rphpool View Post
    I think you're on to something there and I think the effect is stronger or weaker for different people.
    I know when I'm roasting coffee in a little circulating popcorn popper in the back yard and I'm staring down at this rotating mass of coffee beans, when I look over at my voltmeter that's monitoring my heater voltage, the meter numbers briefly distort and rotate - as if they're italicized. I tried to confirm that with my wife and she can't see that effect at all!
    May 2015
    Cincinnati/ohio
    30
    Here is a pic of the standard solution mixed with reagent. Waist high, back to the sun, filled to the 50 ppm line. Dot is very visible. How can this be?
    May 2015
    Cincinnati/ohio
    30
    And here is a pic of my pool water mixed with reagent at 50. If I use the standard as my guideline my cya is much higher than I think it is.
    38,251
    So change the lighting! The dot should be gone at 50ppm.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    She's outside with the sun at her back, what else can she do?
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I would have to agree with the above. I ordered the Taylor test kit to compare with the TFTest Kit. Taylor shows my CYA to be higher than TFTest Kit.
    So, I tried an experiment. When I used the TFTest Kit reagent with the Taylor comparitor I could see the dot all the way up - much further than when using the Taylor reagent. Also, test strips show CYA to be higher at 30-50. Why, when using Taylor reagent, does Taylor show CYA at about 35 and TFTest Kit, when using TFTest Kit reagent, shows it about 22 before you can't see the dot. Then when I substitute the TFTest Kit reagent and use it with the Taylor comparitor it shows about 22 before I can't see the dot. So, what I am saying is that there is a difference in the reagents. I'm not saying one is right or accurate and the other one is wrong, just that there is a difference. Something else, though, the strips show the CYA to be 30-50. It makes me wonder that the true CYA must be above 30.
    Snoufette, I would recommend that you get some test strips (AquaChek made by Hach 100 count are a good choice) and see what they say and then, if you want some more data, go to a couple of pool stores and see what they say. CYA is not something that has to be exact, luckily and we can usually get a ball park figure and go with it.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    38,251
    The reagent is the same. TF-100 uses Taylor reagent. The tubes are different though.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    The pictures are great. I'll try to duplicate that tomorrow and see what I get. Hopefully my pictures come out as good.
    Mar 2007
    San Rafael, CA USA
    12,082
    Dave (duraleigh) is going to check this out on Monday or Tuesday. Let's see if he finds anything wrong, possibly with the melamine reagent.
    May 2015
    Cincinnati/ohio
    30
    Well it's not.... and I've tried to change the lighting. This is actually the "most obscured" I could get.
    Quote Originally Posted by chem geek View Post
    Thanks. I appreciate your help and advice. I am in no way trying to find fault with the standard or reagent. I LOVE my kit and I love testing my water myself. I am kind of addicted. I just want to know what to do with my stabilizer. If I am not measuring it accurately how do I know if I need to add any. And how do I know what my FC should be? Just trying to figure it out. It's the only test I can't get right.
  20. Back To Top    #20
    Mar 2007
    San Rafael, CA USA
    12,082
    Though it's a hard test, it shouldn't be as far off as you are seeing. Something isn't right and we need to sort out what it is.
