Thread: Replacing Jandy side spa remote 100 feet
    Jun 2015
    Naples, FL
    1
    Question Replacing Jandy side spa remote 100 feet
    I've turned off the power. But now I don't know what to do next. Got the replacement side spa remote from Amazon and it is a perfect match, with 100 feet of wire already attached. I think I've got to cut the old remote off, attach the end of the wires on the new remote and carefully pull the whole thing through the conduit. Then, at the other end, attach the wires to the Jandy box on the wall. Does anyone have any experience at this?
    Jun 2015
    Wildomar, California
    423
    Re: Replacing Jandy side spa remote 100 feet
    Welcome Peach Fuzz. Yes, disconnect the wires from the plug so that you can cut off the switch itself and splice the wires their at the side of the spa. Them pull the whole wire length thru the conduit. I've done it over 100 times. Make sure you strip the wires long enough to get a strong connection. Usually I wil then wrap it in electrical tape and cover it with some type of lubricant.
