Become a TFP Supporter Pool School
Results 1 to 14 of 14
Thread: Adding salt
    Member TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    Adding salt
    For the first time, I plan on adding salt to my pool tonight. My salt reading is 2900 ppm. Any special advice? This is what I plan on doing:
    - Turn on pool pump
    - Turn off SWG
    - Add salt around perimeter of pool
    - Brush the sides of the pool for mixing
    - Leave pool on for 24 hours
    - Turn on SWG
    - 25K Gallons, Jandy AquaPure Model Pure1400 SWG w/ AquaLink RS PDA, Jandy LXi Heater Model 400
    - Jandy CV460 Cartridge Filters
    - IG Plaster Pool w/ rock waterfall & weeping walls, Elevated spill-over spa
    - 2 X Jandy Stealth SHPM2.5 pumps (one for pool, one for waterfall), Pool Pump ~ 100 GPM in pool mode
    - UltraPure UPP25 Ozone Generator, Polaris 280 w/ Polaris Halcyon booster pump
    Senior Member no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Adding salt
    Nothing wrong with what you plan, I don't go to that extent, though. I turn off the SWG; use Mortons pool salt, which dissolves pretty quickly; dump it into a narrow spot of my pool which is about 10 feet wide; and brush it back and forth 'til I see it is dissolved. I do it early enough in the day so the pump runs at least a couple of hours after I'm finished, and turn the SWG on the next day. Five minute job... but maybe I'm doing it wrong, though...
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Member SCCS's Avatar
    Sep 2008
    Left coast
    79
    Re: Adding salt
    For adding salt to the pool I use a 5 gallon bucket. I use LESLIE'S salt and I add about half a bag to the bucket and shoot in a powerfull stream of water to mix it up. I dump that in the pool walking around the edge.(their will be some salt left in the bucket, so I just repeat the process one more time) Then dump the rest of the bag in the bucket and repeat the process. No need to brush at all. Oh, and I do have the pump run for about an hour. Just my way of doing things hope it helps.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Senior Member New2Me's Avatar
    Jun 2008
    SW Indiana
    323
    Re: Adding salt
    I would test the water BEFORE adding any salt. If you are just adding 100 pounds of salt(to get your 20,000 gal pool from 2900 ppm to 3500 ppm) I would just dump it in, and leave everything else alone(pump,SWG,ect..) and maybe try brushing it some. A good grade of salt will dissolve quickly, theres no need to wait for 24 hours, or to turn off the SWG, especially if you are in need of CL; if your SWG won't run due to low salt, add bleach now and test the salt level with a test strip, don't rely on the SWG to tell you the level, as a low salt warning could be a problem with the SWG itself; ie.. your pool is actually AT 3500 ppm and the SWG is dirty. Good Luck!!!
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Senior Member JasonLion's Avatar
    37,891
    Re: Adding salt
    There is no need to use pool salt for faster dissolving. Even pellet salt, which does dissolve more slowly, still dissolves quickly enough that it is not a problem. I suggest crystal salt, but anything other than a large single block of salt will work. Simply brush any salt around to spread it out right at first and again after 15 minutes and it should all dissolve reasonably quickly. Leaving the pump on for 24 hours is a great idea, but four hours is probably enough (less if you pre-dissolve).
    Water softener salt, often called solar salt, is the least expensive. You want the kind without any additives or special features, usually in the blue bags, avoid rust remover, iron fighter, and table salt! For example, Cargill/Diamond Crystal Salt Crystals for Water Softener or Morton White Crystal Solar Salt. There are other forms that will work, pool salt, pellets, etc, but the crystals are usually the least expensive (sometimes dramatically so).
    Also, low water temperature can cause some SWGs to read the salt level as lower than it actually is. Some are temperature compensated and some aren't.
    TFP Admin. Creator of PoolMath and Pool Calculator. Other handy links: Support this site, TF Test Kits, Pool School
    Oct 2008
    Houston, TX
    39
    Re: Adding salt
    Thanks for the suggestions.
    I bought Morton's pool salt from Sam's Club. The bucket idea sounds good to me.
    Senior Member
    Ft Lauderdale, Florida
    1,447
    Re: Adding salt
    Some systems will shut down under high salt levels but some may blow fuses. To be safe it's a good idea to just shut the SCG off until the salt is dissolved.
    For adding salt, I agree with Jason's recommendations.
    However, I recommend turning on the pump, switch the valve to draw from the main drain only, then pour the salt into the deep end, as much as you can towards the main drain. Whatever is not dissolved yet, brush towards and into the main drain.
    Saves alot of time, dissolves the salt faster, and avoids the need to have to walk around the perimeter to brush the salt.
    Always have your salt tested the following day to ensure that the salt display matches what the actual salt level is. Calibrate the salt display to match your test results, if that option is available.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Oct 2008
    Houston, TX
    39
    Re: Adding salt
    It was a piece of cake.
    Senior Member launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Re: Adding salt
    Is there any issue with putting the leg of a legging into you skimmer and then pouring the salt in there? You still have the main drain to pull water if the skimmer can't supply enough. That's what I did and the flow over the salt desolved it really quickly. Our pool also has a screened cover you can screw over the return so I filled the other leg of the legging with salt and screwed the cover on. Was kind of neat to see the wavy lines the salt made as it disolved.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Guest
    Re: Adding salt
    I just dump it in the pool with the pump running and let it circulate. I turn off the SWG when I add it and turn it on the next day. I don't even brush it. It dissolves in about 30 minutes. I use solar salt, I put mine in the shallow end because there is a lot of water turbulence from the returns there.
    Remember, your putting salt into a pool, not making an angel food cake!
    Oct 2008
    Houston, TX
    39
    Re: Adding salt
    I tested my water using the AquaChek white strips and I got 3590 ppm!
    Junior Member
    May 2008
    Houston, TX
    20
    Re: Adding salt
    I usually put it in early before the vacuum runs and run the vacuum longer to let it push the salt around.
    Kids are also good at spreading the salt...
    22k gal free form gunite w/spa, Aqualink RS-8, Jandy Aquapure SWG, 2 Jandy ColorLite, Polaris 280, Raypak 400k Low NoX Heater.
    Dec 2007
    Navarre FL
    84
    Re: Adding salt
    My local pool store has salt on sale, aboit 7.40 a 40# bag. Lowes had pool salt at 7.05. The blue bag solor crystal salt was 4.00. I needed 15 bags, guess which one I got!
    I just dumbed it all in the deep end, pushed it around with the brush and it was disolved within an hour.
    22,000 Gunite, Cart Filter, Aquarite SWG
