Results 1 to 8 of 8
Thread: Respirator against Chlorine when adding MA?
    Jun 2015
    Austin, TX
    1
    Hi All,
    I'm using the TFP method for the pool, and as such, my pH tends to drift up, which I balance with muriatic acid.
    For the next batch, I switched to dry acid, but read that it will make the water smell after a while, so I'll switch back to MA.
    My problem is, when I add MA, I can often smell the chlorine, as much as I try to avoid breathing it in.
    I have been researching this on google, but couldn't find out if the respirators I can buy at hardware stores filter out chlorine or not. I'm quite nervous with adding MA at this point because of the fumes.
    Thanks!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: Respirator against Chlorine when adding MA?
    I don't think you are smelling chlorine, but the muratic acid. It does have a very strong smell and you should avoid breathing the fumes.
    Now, with that being said I like to get in front of a return on my hands & knees and splash a little water on the pool deck. Then open the acid bottle and partially submerge it in the water. Tilt the bottle to pour the acid in at close to water level, but don't let the bottle get submerged. I don't measure because it's an additional step for me to spill the stuff and have to smell it more. Remove the bottle from the water and set it down in the puddle on the pool deck while you replace the cap. Try not to breathe the fumes. Paying attention to the direction the wind is blowing and positing yourself up wind will help. Guess a little low on amount you need, then test again after it circulates well. You can always add more.
    I don;'t know of anyone who uses a resparator, so I'm unsure if any are readily available at a reasonable price that would work.
    Support the site
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    christianday wrote "Got a great 3M vapor mask with cartridges specifically designed to filter acid fumes and the googles to match. This was the first time I could not smell that horrid stuff and now I feel a little better using it
    This is the 3M 60923 filter to use. They had a mask at Lowes with those cartridges in it but I can't seem to find it on their site to link. But the filters are pretty interchangeable with the masks from what I could see."
    Might work for you???
    http://www.troublefreepool.com/threa...l=1#post843589
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    30,402
    I add my acid EXACTLY as Tim5055 does. You will become comfortable with that very quickly if you read his post carefully.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    personally, i just measure it out and pour it in. no issues with fumes. i'm weird that way.
    note: wind at your side would be more useful than wind at your back. at your back it curls around your body and just brings the fumes towards you. at your side it will carry them away? right?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Quote Originally Posted by pabeader View Post
    Yeah, that is probably right.
    Jul 2014
    Sacramento, CA
    241
    I generally measure it out into a 32oz plastic measuring cup (labeled "Pool -- Acid Only"; I have a separate one for chlorine) and depending on the wind then step away for a few seconds while the fumes dissipate before pouring it into the pool. It seems to me that the fumes come from opening the bottle more than having it in the measuring cup. I don't wear a respirator, and I don't bother with gloves anymore, as I'm led to believe that MA on the skin won't do immediate damage; there's time to wash it off in the pool. I do wear eye protection always.
    You can also get at HD/Lowes and probably elsewhere 14% concentration MA, much less fuming -- but it's more expensive (I think $12 for 2 gallons of 29%, and $11 for 2 gallons of 14% near me). But if it makes you more comfortable and safer, and more likely to add as needed, a few dollars a month more is worth it. It's often in the same pile, look for the boxes labeled "Pool" vs "Contractor Strength".
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    carpainterinaz's Avatar
    Apr 2015
    Tempe az
    27
    If your going to wear a respirator when you use and dispense MA the 3m 60923 cartridge is the correct one to use.
    We use that cartridge at my shop for chemical stripping paint and for any type of welding or plasma cutting. Just remember to always store the respirator and cartridges in a sealed ziplock bag or container when it's not in use. Exposure to air constantly reduces the life of them.
    7900 Gal custom built in ground beach edge pool
    Custom matched Montego Bay color mini pebble interior finish with abalone shell
    Pentair variable speed pump and cartridge filter
    4 main pool returns and 3 24" sheer descent water falls
    3 Pentair intellibrite led lights in the pool and 2 matching landscape lights
